Reaction wheel inverted pendulum
Hello, I am trying to make a reaction wheel pendulum but I have some issues.
I have the below parts:
  • SimpleFOCShield V2.0.4 (power up the Shield with 12 volt)
  • MPU6050 connected with I2C
  • AS5600 connected in analog A1 pin
  • Gimbal GBM2804H-100T motor
  • and some 3d printed parts as showed in the picture.
First, I started with testing the sensor and I found the min and max values as 16 and 682, respectively. Then, I tried to run the ‘open_loop_velocity_example’ but the motor jiggle in small values and if I try to set the motor target velocity [rad/s] above of 15 many times needs help by hand to start. The ‘open_loop_position_example’ doesn’t work properly, it oscillating again and stop in wrong place. Finally when I try to run the ‘find_pole_pairs_number’ the motor jiggle and the answer is everytime wrong. Have you got any idea for what may goes wrong?
Thank you in advance,
Aristotle
Can you post your code?
Thanks for the prompt reply. This is the code of the open loop that I run, it is the example with some minor changes:
//target variable
float target_velocity = 0;
driver.voltage_limit = 6;
// limiting motor movements
// currnet = resistance*voltage, so try to be well under 1Amp
// open loop control config
// init motor hardware
Serial.println(“Motor ready!”);
Serial.println(“Set target velocity [rad/s]”);
anyone, any thought?
Can you try disconnecting your IMU/gyro and the encoder, and see if it works?
I.e just the three wires for the BLDC should be connected. In open loop, you barely have to have anything configured for it to work correctly, so I think your setup should be fine.
Can you double check the motor is installed correctly (i.e. measure resistance from a pair of screw terminals) and that there are no breaks in the motor?
Thanks,
Matei
