Hi! I´m working in my own reaction wheel with two AS5600 in analogue mode, i just modified the original code of the project, when I start the project the pendulum just get energized and “tremble” but any move. Some recommendantion or help? this is the code:
// BLDC motor initialization
// BLDC driver initialization
// Motor sensor initialization (AS5600 via Analog)
MagneticSensorAnalog motorSensor = MagneticSensorAnalog(A0, 14, 1020);
// Pendulum sensor initialization (AS5600 via Analog)
MagneticSensorAnalog pendulumSensor = MagneticSensorAnalog(A1, 14, 1020);
// Initialize motor sensor hardware
motorSensor.init();
// Initialize pendulum sensor hardware
pendulumSensor.init();
// Driver configuration
// Motor configuration
// Link the motor to the sensor
motor.linkSensor(&motorSensor);
// Link the motor to the driver
// Initialize motor
// Align sensor and start FOC
// Loop down-sampling counter
long loop_count = 0;
// ~1ms
// Pendulum sensor read
pendulumSensor.update();
// Control loop each ~25ms
if (loop_count++ > 25) {
// Calculate the pendulum angle
float pendulum_angle = constrainAngle(pendulumSensor.getAngle() + _PI);
float target_voltage;
if (abs(pendulum_angle) < 0.5) { // If angle small enough stabilize
target_voltage = controllerLQR(pendulum_angle, pendulumSensor.getVelocity(), motor.shaft_velocity);
} else { // Else do swing-up
// Sets 40% of the maximal voltage to the motor in order to swing up
target_voltage = -sign(pendulumSensor.getVelocity()) * driver.voltage_power_supply * 0.4;
// Set the target voltage to the motor
motor.move(target_voltage);
// Restart the counter
loop_count = 0;
// Function constraining the angle between -pi and pi
float constrainAngle(float x) {
x = fmod(x + _PI, _2PI);
if (x < 0)
x += _2PI;
return x - _PI;
// LQR stabilization controller functions
// Calculating the voltage to stabilize the pendulum
float controllerLQR(float p_angle, float p_vel, float m_vel) {
// If angle controllable
// Calculate the control law
// LQR controller u = k*x
// - k = [40, 7, 0.3]
// - x = [pendulum angle, pendulum velocity, motor velocity]'
float u = 40 * p_angle + 7 * p_vel + 0.3 * m_vel;
// Limit the voltage set to the motor
if (abs(u) > driver.voltage_power_supply * 0.7)
u = sign(u) * driver.voltage_power_supply * 0.7;
return u;
// Function to determine the sign of a number
float sign(float value) {
if (value > 0) return 1.0;
if (value < 0) return -1.0;
return 0.0;
