{EDIT: This issue was caused by a bad encoder}
I’m about 0 for 10 with sensors now and staring to think I’m just cursed.
Motor: 42BLS02
Sensor: 1024 PPR quadrature optical encoder 5-24V A/B/I quadrature encoder, coupled to front shaft facing motor
Controller: NUCLEO-64, G431RB
Driver+PowerAmp: FOCShield
Mode: Torque (voltage feedback)
-System start starts, find electrical zero.
-Monitor shows that encoder is wired correctly (shows +6.28 rad if I turn the shaft).
-When I command a torque, the motor spins about a half turn, then halts.
-Per above, I have the encoder coupled to the motor output shaft , facing the motor. I tried reversing the A/B phases to no avail
-The motor works (albeit not optimally) with other encoders (Hall, magnetic), and works great in openloop
Code
#include “Arduino.h”
Encoder encoder = Encoder(3, 2, 1024, 4);
void doC(){encoder.handleIndex();}
BLDCMotor motor = BLDCMotor(4, 1, 250);
// PHASE A B C En
// void doMotor(char* cmd) { command.motor(&motor, cmd); }
void doTarget(char* cmd) {command.scalar(&motor.target, cmd);}
void doLimit(char* cmd) {command.scalar(&motor.voltage_limit, cmd);}
encoder.init();
encoder.enableInterrupts(doA, doB, doC);
motor.linkSensor(&encoder);
driver.voltage_limit = 12;
// link driver
//motor.controller = MotionControlType::velocity;
motor.voltage_sensor_align = 4;
motor.voltage_limit = 2;
motor.current_limit = 10;
motor.velocity_limit = 20;
motor.PID_velocity.P = 0.1;
motor.PID_velocity.I = 0.0;
motor.PID_velocity.output_ramp = 100;
motor.PID_velocity.limit = 20;
// angle loop controller
motor.P_angle.P = 20;
motor.LPF_velocity.Tf = 0.2;
motor.target = 0;
Serial.begin(921600); // WARNING: low value like 115200 cause distorted FOC
motor.monitor_variables = _MON_TARGET | _MON_VOLT_Q | _MON_VOLT_D | _MON_CURR_Q | _MON_CURR_D | _MON_VEL | _MON_ANGLE; // monitor target velocity and angle
//motor.foc_modulation = SpaceVectorPWM;
// initialise motor
// commnads
command.add(‘T’, doTarget, “target”); // ssss space
command.add(‘M’,doMotor,“motor”);
// motor monitoring
