Hi, i tried to use the example from simple_foc to read my encoder output, but it doesn’t work. already had a look with the oscilloscope and the encoder signals look fine. i get the behaviour from the code that i would get if one of the two encoder pins wasn’t triggering. am i using unusable pins or should i look somewhere else? using a stm32F446RE nucleo, with channel A= PA13 and B=PA14, here is the code:
- Encoder example code
- This is a code intended to test the encoder connections and to demonstrate the encoder setup.
Encoder encoder = Encoder(PA13, PA14, 48);
// interrupt routine intialisation
int i=0;
// monitoring port
// enable/disable quadrature mode
encoder.quadrature = Quadrature::ON;
encoder.pullup = Pullup::USE_EXTERN;
encoder.init();
// hardware interrupt enable
Serial.println(“Encoder ready”);
// not doing much for the encoder though
encoder.update();
if (i%100){
Serial.print(encoder.getAngle());
Serial.print(“\t”);
Serial.println(encoder.getVelocity());
i=0;}
i+=1;
