Problems getting roboter arm joint into closed loop angle control
Hi, so for quite some time now I have been trying to get my roboter axis into closed loop control using the simple foc library, but I have stumbled into quite some issues :melting_face:
Here you can see my gimbal bldc motor (GM7008H) in open loop control:
Note that when I enter the target velocity when I run the code the motor starts oscilating and not moving at the desired speed. I have to also put the current limit down using the command prompt, which I find is pretty weird :upside_down_face:
The AS5047p magnetic encoder, which I read out via SPI works great and I already tested it seperately using the code from the github examples.
So here is the code I use for the angle control loop:
MagneticSensorSPI sensor = MagneticSensorSPI(34, 14, 0x3FFF);
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCMotor motor = BLDCMotor(11, 10.8, 28);
BLDCDriver3PWM driver = BLDCDriver3PWM(1, 2, 3, 4);
// angle set point variable
float target_angle = 0;
  // contoller configuration
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 20;
  motor.current_limit = 1;
  // angle P controller
  motor.P_angle.P = 20;
  motor.velocity_limit = 10;
  Serial.begin(9600);
  // align sensor and start FOC
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_angle);
  // motor.monitor();
The bldc motor inits no problem, but then it doesn’t move to the desired position… If I send a target angle it does nothing. But what is interesting if I help with the hand it will move to a position and then hold this position.
Thanks for the help in advance…
