Are you sure the environment is set up correctly? Is this on ArduinoIDE or on PlatformIO?
The UNO R4 support is very new, so there could still be some bugs and problems. But this one looks more like something isn’t setup right - executing an undefined instruction isn’t something that should be caused by a bug in the simplefoc code, but more like a compiler error.
Hi @runger, Thank you for your reply.
I am using R4 wifi with IDE.
I’m not sure what do you mean by environment set up but i’m using SimpleFOC Shieldv2.0.4, SimpleFOC library 2.3 with the R4 PR, the newest version of Arduino IDE and the code that works on Arduino Mega or R3.
However one of the code I use for testing encoder that has include SimpleFOC library in it works well and doesn’t have the error massage. Once I add any code related to motor or driver it will show the error massage again.
Have also tried run the code on other pc, got the same result…
Fault on interrupt or bare metal(no OS) environment
===== Thread stack information =====
addr: 20007e28 data: 00017915
addr: 20007e2c data: 0001772f
If it is then you may need to wait until 1.0.3 of renesas core is released (assuming the fix makes it into that release). You could also try an older version - perhaps this is a regression.
For sure you have to use the dev branch for the moment if you want to use the UNO R4. The code for the Renesas MCU it is using is not yet in the release version of the library.
On the R4 Minima it is working for me.
On the R4 Wifi there is a problem, it crashes.
There seems to be a difference in how the R4 Wifi is using the framework that causes this error.
Am online :-)… I have good experience in doing isolation of problems as a bug tracking practice.
So, if I have - for instance - 40 almost identically looking code pieces, then I would try to temporarily comment them out and see if it still crashes.
Then I would go over the code, first in large blocks, like: Removing one major function call, then if code still crashes, instate that one again and remove another major function call. Thereby one can oftenly in very few minutes eliminate causes.
If it, however, is a reentrance problem, then that tactique is rarely working.
Can you in any way educate me a tad little bit on how the timer stuff is working?
If I get you right, from the thread above, and from your message on the Arduino forum, then the timers are setting the output directly?
That is - no need for any digital/analog write. One could say it is similar to analogWrite(), where you are controlling the cadence of the output yourself by modifying frequency and duty-cycle.
Yes indeed, the timers are being used in a way similar to analogWrite(), in PWM output mode. There is no need for interrupts or asynchronous code in this setup, it’s just the timer peripherals of the MCU directly outputting PWM to the timer pins. The duty cycle and frequency can be controlled by writing to the timer registers (via the FSP functions in the case of Renesas).
I have to say, Arduino isn’t exactly making it easy to collaborate with them looks like they have a rogue GitHub admin…
They locked the first issue I created, leaving me unable to comment any more on it, and then immediately closed a second issue I created, leaving a threatening note. So it looks like I’m left with no way to report on the bug, through no fault of my own… they also took the measure of just deleting the whole “Discussion” option in github, presumably because they didn’t like our discussing there?
Anyway, I find this very problematic behaviour, I didn’t do anything wrong (neither did you!). I’ve complained to Arduino support about it, let’s see what happens.
For anyone interested, there seems to be a bug with the R4 Wifi timer setup, either on my side or the framework side, not clear. But the same SimpleFOC code is working on the R4 Minima and not on the R4 Wifi, which does suggest there is at least a difference in the framework between these two models.
To keep track of the situation around the R4 WiFi, I’ll add my notes here. I guess no one is really using Renesas MCUs here yet, since we only just started supporting them, but perhaps someone will stumble across this and be able to help out
the problem occurs on R4 WiFi, but not on R4 Minima
the MCU hard-crashes, shortly after initialising the timers
the crash occurs asynchronously, also if the main loop is in a blocking loop ( while (1); )
the stack contains, among other stuff, a reference to the agt_int_isr (AGT interrupt handler) and a corrupted stack entry at the top:
0x000000c0
??:0
the crash occurs independently of whether I start the timers or not
the crash occurs only when I use GPT timer channels 2-8, but not for channels 0 and 1
the crash occurs whether or not debug output via Serial is enabled or not
My current hypothesis is that the agt timer interrupt is somehow being called for the GPT timers, there is no irq handler set for these, so it jumps to 0 and crashes
Not sure why that would happen though.
Also not at all clear why it would happen on the R4 WiFI, and not on the Minima, so perhaps it is not the best explanation after all
Regarding the timer channels, the difference between GPT channels 0/1 and 2-8 is that CH0 and CH1 are 32 bit timers, while CH2-8 are 16 bit. So perhaps the crash would eventually occur on channels 0/1 as well, but it just takes 2^16 times longer to happen.
Sorry to hear that, probably they are playing catch up and are more than a little stressed, alas… I don’t agree with the approach Arduino is taking these days. They have contributed enormously to the community but are trending in a troubling direction recently.
I don’t know anything about that, and it’s unclear to me whether the person is actually involved with Arduino or “just” a contributor. It doesn’t really matter I guess.
I think they have contributed a lot to open source, and the “maker community”. Also, they make some pretty nice boards, and they deliver them to my door within 48 hours of me ordering. That’s pretty good.
In the end, I would just like to post my bug, and track progress on it. I really don’t think I did anything wrong here, and find it hard to understand why they’re making it impossible for me to help them, which is in the end what I’m doing when tracking down this bug. Perhaps they’re motivating me to find the solution by myself Maybe they don’t want issues that don’t come with a PR ready to go.
Those are PRs, not issues IMO
I read the issues too, it seems like the issue was moving quite too fast for anyone upstream to keep track of, but closing the issue made no sense…
Dear Runger and Anthony Douglas, I have - anonymously for you guys - raised the issue about this behaviour with the group management of Arduino, by the so called “invited contributors” on the Arduino site. I share your view that it is highly likely someone who have grown a big head for maybe having been promoted to be a contributor.
In my view, I think the point would always be to keep a problem and the dialogue about it, coherent and together.
In my view, if I was configuration manager with Arduino, I would split the problems up into the problem related to the SIMPLEFOC library/software and the problem related to if the timer is making problems in the Arduino UNO R4 Wifi - compared to the other one where it works.
Thereby the dialogue related to the Arduino core library would take place, there, and the dialogue related to simplefoc would take place in its own forum.
And - every time there is a “spill over” from one leg/branch to the other - it would happen within the same repository.
It is my take, that until it is proven that the bug is not from the library - since it is identifcal code which runs differently on the two almost identifcal R4 platforms - then it is indeed a relevant topic to discuss on the R4 library github.
Well. That was not the take of the invited contributor Per1234 from Arduino - so let us see. I find it offensive the way he was talking and threatening (we call it “shouting”) - that is uncouth, and should not happen in a forum with adult, highly educated, considerate and professional contributors like all of us.
Let peace bestow the fora, and let these rogue individuals (Per1234 et al) find their bearings without threats and similar nonse.
Not sure this is the best place to post this but I seem to be having some bug with the Dev branch on the R4 Wifi. Using the full control example with MotionControlType :: angle and the commander to set position targets works great but when I force the motor to have an angle error it runs away uncontrollably and unrecoverable. Same sketch on the R3 works as one would expect. The PID loop fights back and corrects the error. Using the same hardware and simpleFOCSheild on both.
I also have a haptics texture sketch I am messing around with on both using TorqueControlType::voltage and that seems to work with no issues.
thanks for reporting it! We seem to have a hard to find bug relating to this, several users have reported similar problems in different setups and situations. It does seem to be related to the more advanced modes like velocity and position modes.
If you can narrow it down any further, it would certainly be helpful. It’s something that affects only some users / setups, so it is proving hard to find.
Setup 1 is an iPower GM4108-120 with an AMT 103 encoder as the sensor.
Setup 2 is an iPower GM5208-12 with an integrated AS5048A running SPI as the sensor.
Both are using FOCshields V2.0.4.
Both run as expected on an R3. You can force the motor to a large angle error (> 1.5 radians) and it corrects with no issue. On the R4 they both respond to commands great and can correct from small angle errors but anything over say 0.05 radians it runs away uncontrollable in the direction of the error. Commanding a new angle during runway does nothing. Even if you set the new target out ahead of the direction its running. I have not found away to get it out of that state.
Below is the basic code I am using. I update the sensor type and associated code when going between encoder and mag SPI.
Please let me know if there is any other info that would be helpful or if there is anything you want me to try out.
// encoder instance
Encoder encoder = Encoder(2, 3, 2048);
// channel A and B callbacks
// angle set point variable
float target_angle = 180;
void onMotion(char* cmd) { command.motion(&motor, cmd); }
encoder.init();
motor.linkSensor(&encoder);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 10;
motor.PID_velocity.D = 0.0;
motor.voltage_limit = 12;
motor.PID_velocity.output_ramp = 100;
// angle P controller
motor.P_angle.P = 5;
motor.velocity_limit = 15;
//display variables
motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE;
// downsampling
motor.monitor_downsample = 100; // default 10
//command.add('T', onTarget, "target angle");
command.add('M', onMotion, "motion control");
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
