Hey martin,
I’ve dug into the code a bit and it seems that the stm32L0x
family is very constrained featurewise and it does not really support 6pwm in hardware and in software it is almost certain it will not work as too.
But the good news it that it will work for 3pwm and I’ll update the next library version for it.
For now, if you want to test the code you can replace the whole contents of your \src\drivers\hardware_specific\stm32_mcu.cpp
file with :
#include "../hardware_api.h"
#if defined(_STM32_DEF_)
// default pwm parameters
#define _PWM_RESOLUTION 12 // 12bit
#define _PWM_RANGE 4095.0 // 2^12 -1 = 4095
#define _PWM_FREQUENCY 25000 // 25khz
#define _PWM_FREQUENCY_MAX 50000 // 50khz
// 6pwm parameters
#define _HARDWARE_6PWM 1
#define _SOFTWARE_6PWM 0
#define _ERROR_6PWM -1
// setting pwm to hardware pin - instead analogWrite()
void _setPwm(int ulPin, uint32_t value, int resolution)
PinName pin = digitalPinToPinName(ulPin);
TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(pin, PinMap_PWM);
uint32_t index = get_timer_index(Instance);
HardwareTimer *HT = (HardwareTimer *)(HardwareTimer_Handle[index]->__this);
uint32_t channel = STM_PIN_CHANNEL(pinmap_function(pin, PinMap_PWM));
HT->setCaptureCompare(channel, value, (TimerCompareFormat_t)resolution);
// init pin pwm
HardwareTimer* _initPinPWM(uint32_t PWM_freq, int ulPin)
if (HardwareTimer_Handle[index] == NULL) {
HardwareTimer_Handle[index]->__this = new HardwareTimer((TIM_TypeDef *)pinmap_peripheral(pin, PinMap_PWM));
HardwareTimer_Handle[index]->handle.Init.CounterMode = TIM_COUNTERMODE_CENTERALIGNED3;
HAL_TIM_Base_Init(&(HardwareTimer_Handle[index]->handle));
HT->setMode(channel, TIMER_OUTPUT_COMPARE_PWM1, pin);
HT->setOverflow(PWM_freq, HERTZ_FORMAT);
HT->pause();
HT->refresh();
return HT;
// init high side pin
HardwareTimer* _initPinPWMHigh(uint32_t PWM_freq, int ulPin)
return _initPinPWM(PWM_freq, ulPin);
// init low side pin
HardwareTimer* _initPinPWMLow(uint32_t PWM_freq, int ulPin)
TIM_OC_InitTypeDef sConfigOC = TIM_OC_InitTypeDef();
sConfigOC.OCMode = TIM_OCMODE_PWM2;
sConfigOC.Pulse = 100;
sConfigOC.OCPolarity = TIM_OCPOLARITY_LOW;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
#if !defined(STM32L0xx) // L0 boards dont have these entries
sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfigOC.OCIdleState = TIM_OCIDLESTATE_SET;
sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
#endif
HAL_TIM_PWM_ConfigChannel(&(HardwareTimer_Handle[index]->handle), &sConfigOC, channel);
HT->setMode(channel, TIMER_OUTPUT_COMPARE_PWM2, pin);
HT->pause();
HT->refresh();
return HT;
// align the timers to end the init
void _alignPWMTimers(HardwareTimer *HT1,HardwareTimer *HT2,HardwareTimer *HT3)
HT1->pause();
HT1->refresh();
HT2->pause();
HT2->refresh();
HT3->pause();
HT3->refresh();
HT1->resume();
HT2->resume();
HT3->resume();
void _alignPWMTimers(HardwareTimer *HT1,HardwareTimer *HT2,HardwareTimer *HT3,HardwareTimer *HT4)
HT1->pause();
HT1->refresh();
HT2->pause();
HT2->refresh();
HT3->pause();
HT3->refresh();
HT4->pause();
HT4->refresh();
HT1->resume();
HT2->resume();
HT3->resume();
HT4->resume();
// configure hardware 6pwm interface only one timer with inverted channels
HardwareTimer* _initHardware6PWMInterface(uint32_t PWM_freq, float dead_zone, int pinA_h, int pinA_l, int pinB_h, int pinB_l, int pinC_h, int pinC_l)
#if !defined(STM32L0xx) // L0 boards dont have hardware 6pwm interface
PinName uhPinName = digitalPinToPinName(pinA_h);
PinName ulPinName = digitalPinToPinName(pinA_l);
PinName vhPinName = digitalPinToPinName(pinB_h);
PinName vlPinName = digitalPinToPinName(pinB_l);
PinName whPinName = digitalPinToPinName(pinC_h);
PinName wlPinName = digitalPinToPinName(pinC_l);
TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(uhPinName, PinMap_PWM);
HardwareTimer_Handle[index]->__this = new HardwareTimer((TIM_TypeDef *)pinmap_peripheral(uhPinName, PinMap_PWM));
((HardwareTimer *)HardwareTimer_Handle[index]->__this)->setOverflow(PWM_freq, HERTZ_FORMAT);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(uhPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, uhPinName);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(ulPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, ulPinName);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(vhPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, vhPinName);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(vlPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, vlPinName);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(whPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, whPinName);
HT->setMode(STM_PIN_CHANNEL(pinmap_function(wlPinName, PinMap_PWM)), TIMER_OUTPUT_COMPARE_PWM1, wlPinName);
// dead time is set in nanoseconds
uint32_t dead_time_ns = (float)(1e9f/PWM_freq)*dead_zone;
uint32_t dead_time = __LL_TIM_CALC_DEADTIME(SystemCoreClock, LL_TIM_GetClockDivision(HT->getHandle()->Instance), dead_time_ns);
LL_TIM_OC_SetDeadTime(HT->getHandle()->Instance, dead_time); // deadtime is non linear!
LL_TIM_CC_EnableChannel(HT->getHandle()->Instance, LL_TIM_CHANNEL_CH1 | LL_TIM_CHANNEL_CH1N | LL_TIM_CHANNEL_CH2 | LL_TIM_CHANNEL_CH2N | LL_TIM_CHANNEL_CH3 | LL_TIM_CHANNEL_CH3N);
HT->pause();
HT->refresh();
HT->resume();
return HT;
#else
return nullptr; // return nothing
#endif
// returns 0 if each pair of pwm channels has same channel
// returns 1 all the channels belong to the same timer - hardware inverted channels
// returns -1 if neither - avoid configuring - error!!!
int _interfaceType(const int pinA_h, const int pinA_l, const int pinB_h, const int pinB_l, const int pinC_h, const int pinC_l){
PinName nameAH = digitalPinToPinName(pinA_h);
PinName nameAL = digitalPinToPinName(pinA_l);
PinName nameBH = digitalPinToPinName(pinB_h);
PinName nameBL = digitalPinToPinName(pinB_l);
PinName nameCH = digitalPinToPinName(pinC_h);
PinName nameCL = digitalPinToPinName(pinC_l);
int tim1 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameAH, PinMap_PWM));
int tim2 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameAL, PinMap_PWM));
int tim3 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameBH, PinMap_PWM));
int tim4 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameBL, PinMap_PWM));
int tim5 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameCH, PinMap_PWM));
int tim6 = get_timer_index((TIM_TypeDef *)pinmap_peripheral(nameCL, PinMap_PWM));
#if defined(STM32L0xx) // L0 boards dont have hardware 6pwm interface
if(tim1 == tim2 && tim3==tim4 && tim5==tim6)
return _SOFTWARE_6PWM; // software 6pwm interface - each pair of high-low side same timer
else
return _ERROR_6PWM; // might be error avoid configuration
#else // the rest of stm32 boards
if(tim1 == tim2 && tim2==tim3 && tim3==tim4 && tim4==tim5 && tim5==tim6)
return _HARDWARE_6PWM; // hardware 6pwm interface - only on timer
else if(tim1 == tim2 && tim3==tim4 && tim5==tim6)
else
#endif
// function setting the high pwm frequency to the supplied pins
// - Stepper motor - 2PWM setting
// - hardware speciffic
void _configure2PWM(long pwm_frequency,const int pinA, const int pinB) {
if( !pwm_frequency || !_isset(pwm_frequency) ) pwm_frequency = _PWM_FREQUENCY; // default frequency 25khz
else pwm_frequency = _constrain(pwm_frequency, 0, _PWM_FREQUENCY_MAX); // constrain to 50kHz max
// center-aligned frequency is uses two periods
pwm_frequency *=2;
HardwareTimer* HT1 = _initPinPWM(pwm_frequency, pinA);
HardwareTimer* HT2 = _initPinPWM(pwm_frequency, pinB);
// allign the timers
_alignPWMTimers(HT1, HT2, HT2);
// - BLDC motor - 3PWM setting
void _configure3PWM(long pwm_frequency,const int pinA, const int pinB, const int pinC) {
pwm_frequency *=2;
HardwareTimer* HT3 = _initPinPWM(pwm_frequency, pinC);
_alignPWMTimers(HT1, HT2, HT3);
// - Stepper motor - 4PWM setting
void _configure4PWM(long pwm_frequency,const int pinA, const int pinB, const int pinC, const int pinD) {
pwm_frequency *=2;
HardwareTimer* HT4 = _initPinPWM(pwm_frequency, pinD);
_alignPWMTimers(HT1, HT2, HT3, HT4);
// function setting the pwm duty cycle to the hardware
//- hardware speciffic
void _writeDutyCycle2PWM(float dc_a, float dc_b, int pinA, int pinB){
// transform duty cycle from [0,1] to [0,4095]
_setPwm(pinA, _PWM_RANGE*dc_a, _PWM_RESOLUTION);
_setPwm(pinB, _PWM_RANGE*dc_b, _PWM_RESOLUTION);
void _writeDutyCycle3PWM(float dc_a, float dc_b, float dc_c, int pinA, int pinB, int pinC){
_setPwm(pinC, _PWM_RANGE*dc_c, _PWM_RESOLUTION);
void _writeDutyCycle4PWM(float dc_1a, float dc_1b, float dc_2a, float dc_2b, int pin1A, int pin1B, int pin2A, int pin2B){
_setPwm(pin1A, _PWM_RANGE*dc_1a, _PWM_RESOLUTION);
_setPwm(pin1B, _PWM_RANGE*dc_1b, _PWM_RESOLUTION);
_setPwm(pin2A, _PWM_RANGE*dc_2a, _PWM_RESOLUTION);
_setPwm(pin2B, _PWM_RANGE*dc_2b, _PWM_RESOLUTION);
// Configuring PWM frequency, resolution and alignment
// - BLDC driver - 6PWM setting
// - hardware specific
int _configure6PWM(long pwm_frequency, float dead_zone, const int pinA_h, const int pinA_l, const int pinB_h, const int pinB_l, const int pinC_h, const int pinC_l){
else pwm_frequency = _constrain(pwm_frequency, 0, _PWM_FREQUENCY_MAX); // constrain to |%0kHz max
pwm_frequency *=2;
// find configuration
int config = _interfaceType(pinA_h, pinA_l, pinB_h, pinB_l, pinC_h, pinC_l);
// configure accordingly
switch(config){
case _ERROR_6PWM:
return -1; // fail
break;
case _HARDWARE_6PWM:
_initHardware6PWMInterface(pwm_frequency, dead_zone, pinA_h, pinA_l, pinB_h, pinB_l, pinC_h, pinC_l);
break;
case _SOFTWARE_6PWM:
HardwareTimer* HT1 = _initPinPWMHigh(pwm_frequency, pinA_h);
_initPinPWMLow(pwm_frequency, pinA_l);
HardwareTimer* HT2 = _initPinPWMHigh(pwm_frequency,pinB_h);
_initPinPWMLow(pwm_frequency, pinB_l);
HardwareTimer* HT3 = _initPinPWMHigh(pwm_frequency,pinC_h);
_initPinPWMLow(pwm_frequency, pinC_l);
break;
return 0; // success
// Function setting the duty cycle to the pwm pin (ex. analogWrite())
void _writeDutyCycle6PWM(float dc_a, float dc_b, float dc_c, float dead_zone, int pinA_h, int pinA_l, int pinB_h, int pinB_l, int pinC_h, int pinC_l){
// set pwm accordingly
switch(config){
_setPwm(pinA_h, _PWM_RANGE*dc_a, _PWM_RESOLUTION);
_setPwm(pinB_h, _PWM_RANGE*dc_b, _PWM_RESOLUTION);
_setPwm(pinC_h, _PWM_RANGE*dc_c, _PWM_RESOLUTION);
break;
_setPwm(pinA_l, _constrain(dc_a + dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
_setPwm(pinA_h, _constrain(dc_a - dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
_setPwm(pinB_l, _constrain(dc_b + dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
_setPwm(pinB_h, _constrain(dc_b - dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
_setPwm(pinC_l, _constrain(dc_c + dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
_setPwm(pinC_h, _constrain(dc_c - dead_zone/2, 0, 1)*_PWM_RANGE, _PWM_RESOLUTION);
break;
#endif
I’ve just changed the _initPinPWMLow
, _initHardware6PWMInterface
and _interfaceType
functions.
