Pp number very high
Hi.
My setup: 1.8 deg stepper motor 42STH60-1206A (nema 17), l298n, encoder Autonics E40H12-5000-6-L-5, 5000 ppr.
I’ve tried running example “find_pole_pairs_number”. The results are shown in the figure. After finding the poles, the motor starts to vibrate slightly and make noise. I tried to start the engine in angle_openloop mode, everything works fine. I also tested the encoder with the “encoder example”. Works fine too. What could be the problem?
Code
// Stepper motor instance
// its important to put pole pairs number as 1!!!
StepperMotor motor = StepperMotor(1);
StepperDriver4PWM driver = StepperDriver4PWM(PE9, PE11, PE13, PE14, PD0, PD1);
//  Encoder(int encA, int encB , int cpr, int index)
Encoder encoder = Encoder(PA0, PA1, 5000);
// interrupt routine intialisation
  encoder.quadrature = Quadrature::OFF;
  encoder.init();
  // hardware interrupt enable
  motor.linkSensor(&encoder);
  // power supply voltage
  // default 12V
  // monitoring port
  // pole pairs calculation routine
  Serial.println("Pole pairs (PP) estimator");
  Serial.println("-\n");
  float pp_search_voltage = 6; // maximum power_supply_voltage/2
  float pp_search_angle = 6*M_PI; // search electrical angle to turn
  // move motor to the electrical angle 0
  motor.voltage_limit=pp_search_voltage;
  motor.move(0);
  // read the encoder angle
  float angle_begin = encoder.getAngle();
  Serial.println(angle_begin);
  _delay(50);
  // move the motor slowly to the electrical angle pp_search_angle
  float motor_angle = 0;
  while(motor_angle <= pp_search_angle){
    motor_angle += 0.01;
    motor.move(motor_angle);
  // read the encoder value for 180
  float angle_end = encoder.getAngle();
  Serial.println(angle_end);
  _delay(50);
  // turn off the motor
  motor.move(0);
  // calculate the pole pair number
  int pp = round((pp_search_angle)/(angle_end-angle_begin));
  Serial.print(F("Estimated PP : "));
  Serial.println(pp);
  Serial.println(F("PP = Electrical angle / Encoder angle "));
  Serial.print(pp_search_angle*180/M_PI);
  Serial.print("/");
  Serial.print((angle_end-angle_begin)*180/M_PI);
  Serial.print(" = ");
  Serial.println((pp_search_angle)/(angle_end-angle_begin));
  Serial.println();
  // a bit of monitoring the result
  if(pp <= 0 ){
    Serial.println(F("PP number cannot be negative"));
    Serial.println(F(" - Try changing the search_voltage value or motor/encoder configuration."));
    return;
  }else if(pp > 30){
    Serial.println(F("PP number very high, possible error."));
  }else{
    Serial.println(F("If PP is estimated well your motor should turn now!"));
    Serial.println(F(" - If it is not moving try to relaunch the program!"));
    Serial.println(F(" - You can also try to adjust the target voltage using serial terminal!"));
  // set FOC loop to be used
  // set the pole pair number to the motor
  motor.pole_pairs = pp;
  //align encoder and start FOC
  Serial.println(F("\n Motor ready."));
// uq voltage
float target_voltage = 2;
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_voltage);
  // communicate with the user
  serialReceiveUserCommand();
  static String received_chars;
  while (Serial.available()) {
    // get the new byte:
    received_chars += inChar;
    // end of user input
    if (inChar == '\n') {
      // change the motor target
      target_voltage = received_chars.toFloat();
      Serial.print("Target voltage: ");
      Serial.println(target_voltage);
      // reset the command buffer
      received_chars = "";
Hey @Pavel_Sannikov,
In the terminal it seems that the sensor has measured only 3 degrees change?
Does your motor move when you run this example?
Can you change the pp_search_angle to something like:
 float pp_search_angle = 20*M_PI; // search electrical angle to turn
You can also play with the voltage limit:
 float pp_search_voltage = 6; // rise or lower to see the different effects
When you say that the encoder works well, does that mean that one turn of the motor is results in exactly 6.28 radian angle?
Also, your pole pair number for this nema17 motor will be 50, so you can use it as a debugging value. Once you get 50 that means that everything works well. :smiley:
Thank you very much for your reply. Didn’t expect you to respond so quickly. I will definitely try your tips on July 14th and report the results. Now there is no access to the motor. Thanks a lot again.
It turns quite a bit to both sides with a nasty sound.
