Howdy Powermasters! I am curious if by powering the UNO with a 12v power psu, will the Shield get adequate current. Just started my setup and power gets to the motor but I am not sure if this way is safe longterm. I can easily hook power up the Shield directly but since the 12v is already powering the UNO it would be a nice setup. Thanks.
I think the 12V from the UNO is regulated down before it is exposed anywhere on the board, including the headers. The Vin pin is used for supplying already-regulated power to the board.
You say it is already working. What voltage is the motor supply? Are you using the 5V?
TLDR: I think you need to supply motor power to the shield in addition.
Thanks. Will measure and report later.
