Postion control question
I am running SimpleFOC on the following setup
Ardunio Mega,
DRV8302 driver
1024 ppr encoder
Maxon 4 pole pair motor
Torque Control is Voltage
Motion Control is Angle
I have been trying to tune my setup for position / angle control but can’t seem to get over this behavior.
The blue = Target, Yellow = Angle, Green = Velocity, Red = Voltage.
As you can see the motor moves to 60% of the target very quickly then takes ages (approx 5 secs ) to move the rest.
I have tried increasing the P term in the angle loop but this just give big oscillations in a steady state.
What should I be adjusting?
I’m a newbie in this, but here are some hints from my short experience:
  • First you need to tune the velocity PID, because I think the angle control mode is based, underneath, on the velocity control mode. So set Motion Control to “Velocity” and look at the velocity curve when you suddenly change the velocity from 0 to X rad/sec. You need to achieve a velocity change that looks like the green curve here :
  • When the velocity PID is correctly tuned, you can get back to Angle Motion Control and tune the angle PID the same way. However, the angle PID is usually more simple, something like 20;0;0 (P only).
  • Would you please provide all your PID values? My guess is that you should increase “I” in the velocity PID.
  • Don’t be afraid if you don’t get very good result in Voltage mode. You need to start in Voltage mode in order to tune the Velocity PID then Angle PID in isolation. But then you’ll need to switch to Current modes to achieve better results (this will add more headache, though, cause this will add 1 or 2 more PIDs).
Thanks quentin,
like you, I am a newbie to FOC and brushless motors but have a little understanding of control theory.
I tune the motor first in Voltage and Velocity modes and got a good response to step changes. It it is a fairly high-power Maxon motor currently running with no load. P =1.8, I=0, D=0. When I first went to angle control I got terrible oscillations even with it holding zero position. I found detuning the P term on the velocity controller down to 0.5 helped.
The P term on the angle controller is currently set to 3 if I increase it the oscillations come back.
What looks strange is if you look at the response of the angle position (yellow) is very fast to respond but then slows causing a knee in the line.
You’ll have to tune your PID parameters. When setting up a motor with SimpleFOC, it is usually really helpful to start simple and get more complicated…
E.g. is your motor working as expected in open loop velocity mode?
Once that is working, add the sensor and start tuning your PID values for voltage mode. For a Maxon motor these could be quite different to the examples in the library.
Generally speaking, zero P, I & D, and increase P until you get as close to your target (velocity/position) as you can but without getting oscillations. Then increase I until you get a nice, quick response. D can usually be left on 0, sometimes it helps to set it to a very low value.
It is also conceivable that there is an electrical problem, for example the DRV8302’s OCP kicking in because the currents are getting too high. You could check this by monitoring the nOCTW pin. Or you could test your setup (with unloaded motor) with a lower voltage_limit so as to be sure the current stays in spec.
I assume the red line (voltage) is the output voltage as calculated by simplefoc?
Thanks runger for your input (anybody else feel free to jump in)
Yes, I have gone through all the basic steps, test the motor, driver and encoder. The motor seems to be working fine in open loop control. Although I had to keep the voltage low to stop excessive heating (but I think that normally for a low resistance motor in open loop)
As I said before the response in velocity control seems very good. If I increase P to high I do get oscillations.
You might be right about the DRV8302’s OCP kicking in. I try some more experiments. Current monitoring is next on my list of thing to try.
Yes you are right the red line is Volt_Q from the monitor line
Hey, wow, one month has passed - I’ve been so busy! Have you resolved this issue? It would be interesting to know if you got the Maxon motor working…
Looking at the red line, its interesting to see the rise and then the sudden dip. Since the V_Q is an output of the FOC algorithm, it means the algorithm is deciding to stop accelerating at the peak point, which correlates to the knee in the angle…
Did increasing the I term fix this?
Sorry for the delay in replying. I have stepped away from Simple FOC for a while but am back now.
The short answer is NO I never resolved the issue but will be back revisiting it.
My setup has evolved a little in the fact that I am now using an ESP32 MCU my reason for using this is processor speed and I have ambistious targets for speed and control. I hope this is a good idea.
Yes, ESP32 is well supported. If possible, choose one with MCPWM support, so the older ESP32 Wrover, Wroom etc series, and not the S2 or C3, which do not have this support.
ESP32 is very fast, and has tons of communications options, it is a very nice MCU!
I had a quick look MCPWM, it all looks a bit daunting for my level.
What advantages does it offer over regular PWM?
Hi @Rollmop ,
You don’t have to worry about the details :slight_smile: if you choose the right chip, then SimpleFOC Library will handle everything for you transparently and internally. You’ll just be using the same BLDCDriver3PWM or BLDCDriver6PWM driver as usual for SimpleFOC.
Specifically the advantages of the MCPWM are:
  • it has what is called “dead time insertion” so it can do 6-PWM control. The normal PWM driver can only do 3-PWM control.
  • it will allow “centre aligned” PWM, the normal PWM can only do left-aligned PWM. Centre Aligned will lead to smoother motion and better behavior of the motor in some situations.
MCPWM is basically the correct tool for motor control, while the PWM we use on the S2 or C3 is more a kind of “hack”, and this PWM peripheral is not really intended for motor control.
Ok that might be worth looking into then.
Is there a list of ESP32’s that support MCPWM? I am only just getting to know the ESP32 and there seem to be many versions to add to my confusion.
These ESP32s have MPWM:
ESP32-D0WD-V3
ESP32-U4WDH
ESP32-S0WD
ESP32-D0WD – Not Recommended for New Designs (NRND)
ESP32-D0WDQ6 – Not Recommended for New Designs (NRND)
ESP32-D0WDQ6-V3 – Not Recommended for New Designs (NRND)
ESP32­-PICO­-D4
These ones have no MPWM:
ESP32-S2
ESP32-S2FH2
ESP32-S2FH4
ESP32-S2FN4R2
ESP32-S2R2
ESP32-C3FN4 (ESP32-C3-MINI-1, ESP32-C3-MINI-1U)
That’s a quick search, this list may not be complete.
Thank you good info. I’ll have a close look at the one I have
