Position Control Problem With Hall Sensors for BLDC
Hello all! I have recently build a BLDC motor controller which works great. I have tested and implemented it with hall sensors and am able to get good performance with some velocity code. I am now trying to write the position code equivalent so that I will be able to implement “holds” where the bldc motor will stop moving and hold it’s position. This is because I plan to use it to build a robotic arm in which position holds will be needed. Is there any way to implement a position hold with the hall sensor velocity code? Setting velocity to 0 doesnt seem to work well as it jitters like crazy. I understand the position control code has support for this but it doesnt seem to work - it calibrates and moves to the hall sensors find but when it hits the main loop it stutters a ton not really moving. Any thoughts to the problem? Any help is appreciated!
This is the working hall sensor velocity code which I’ve tested to work:
// Define the BLDC motor pins
#define BLDC_PWM_UH_GPIO 12
#define BLDC_PWM_UL_GPIO 11
#define BLDC_PWM_VH_GPIO 10
#define BLDC_PWM_VL_GPIO 9
#define BLDC_PWM_WH_GPIO 8
#define BLDC_PWM_WL_GPIO 18
#define DRV0_CSN_PIN 48
#define DRV1_SCK_PIN 47
#define HALLU_PIN 6
#define HALLV_PIN 7
#define HALLW_PIN 15
#define ENABLE_PIN 38
#define POLE_PAIRS 2 // Number of permanent magnets in motor divided by 2
// Create BLDCMotor and BLDCDriver6PWM objects
BLDCMotor motor = BLDCMotor(POLE_PAIRS);  // number of pole pairs
BLDCDriver6PWM driver = BLDCDriver6PWM(BLDC_PWM_UH_GPIO, BLDC_PWM_UL_GPIO, BLDC_PWM_VH_GPIO, BLDC_PWM_VL_GPIO, BLDC_PWM_WH_GPIO, BLDC_PWM_WL_GPIO);
// hall sensor instance
HallSensor sensor = HallSensor(HALLU_PIN, HALLV_PIN, HALLW_PIN, POLE_PAIRS);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
float target_velocity = -80;
unsigned long previousMillis = 0;  // will store last time LED was updated
  pinMode(ENABLE_PIN, OUTPUT);
  pinMode(DRV0_CSN_PIN, OUTPUT);
  pinMode(DRV1_SCK_PIN, OUTPUT);
  digitalWrite(DRV1_SCK_PIN, LOW);
  digitalWrite(DRV0_CSN_PIN, HIGH);
  digitalWrite(ENABLE_PIN, LOW);
  delay(250);
  digitalWrite(ENABLE_PIN, HIGH);
  //SimpleFOCDebug::enable(&Serial);
  // initialize sensor sensor hardware
  // aligning voltage [V]
  // contoller configuration
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 2;
  motor.voltage_limit = 2;
  // align sensor and start FOC
  previousMillis = millis();
  /*unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= 2100)
    previousMillis = currentMillis;
    target_velocity *= -1;
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  // motor.monitor();
This is the position control code that I am trying to get working but has problems in the main loop. It just stutters and wont move to the position after calibrating the hall sensors:
#define HALLU_PIN 6
#define HALLV_PIN 7
// angle set point variable
float target_angle = 2;
  delay(250);
  // initialize sensor hardware
  // angle P controller
  motor.P_angle.P = 100;
  motor.velocity_limit = 100;
  //Serial.println(F("Set the target angle using serial terminal:"));
  motor.move(target_angle);
  // motor.monitor();
Thank you for your time!
4
For one thing, your motor.Angle_P.P is probably too high. Usually around 20 is best.
Add this in your main loop before motor.move
  // Don't try to stop between cogging steps
  if (motor.controller == MotionControlType::angle) {
    float c = _PI_3/motor.pole_pairs;
    target_angle = floor(target_angle / c + 0.5f) * c;
The HallSensor angle only changes in whole steps, so if the target is inbetween two of them, the motor will oscillate back and forth, never able to get the sensor exactly equal to target.
@dekutree64 This definitely helps! This got it moving but when it approaches the endpoint it doesnt come to a stop and just jitters around it. Any thoughts? Thanks so much for your help! – robosnake26 just now
Probably just more tuning needed. Keep reducing the angle P and see if it becomes stable or continues oscillating very slowly. And try adjusting the velocity values as well. Usually PID_Velocity.I should be about 10x PID_Velocity.P like you have it, but one of my motors has P=0.05 and I=1.0, so 20x difference.
@dekutree64 you’re right! I halved my P to .1 and it works fine now. thanks for your help!
