MagneticSensorI2C sensor1 = MagneticSensorI2C(AS5600_I2C);
TwoWire Wire1(PB11, PB10);
BLDCDriver3PWM driver = BLDCDriver3PWM(PB1, PB0, PA7, 8);
BLDCMotor motor1 = BLDCMotor(7);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(PB9, PA1, PB8, 8);
float speed = 0.000f;
int xValue = 0;
int yValue = 0;
bool messageStarted = false;
byte receivedBytes[4];
int byteIndex = 0;
HardwareSerial Serial3(PC11, PC10);
sensor1.init(&Wire1);
motor.linkSensor(&sensor1);
motor1.linkSensor(&sensor);
// power supply voltage
driver.voltage_power_supply = 9;
driver1.voltage_power_supply = 9;
driver1.init();
motor1.linkDriver(&driver1);
// aligning voltage
motor.velocity_index_search = 0.5;
// aligning voltage
motor1.voltage_sensor_align = 2;
motor1.foc_modulation = FOCModulationType::SinePWM;
motor1.controller = MotionControlType::torque;
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 10;
motor.voltage_limit = 9;
motor.PID_velocity.output_ramp = 9999;
motor.LPF_velocity.Tf = 0.05f;
motor1.PID_velocity.P = 0.2f;
motor1.PID_velocity.I = 10;
motor1.PID_velocity.D = 0;
motor1.voltage_limit = 9;
motor1.PID_velocity.output_ramp = 9999;
motor1.LPF_velocity.Tf = 0.05;
motor1.init();
// align sensor and start FOC
motor1.initFOC();
Serial3.begin(115200);
Serial.println(“Setup Done”);
while (Serial3.available() > 0) {
char receivedChar = Serial3.read();
if (receivedChar == '<') {
// Start of message
byteIndex = 0;
messageStarted = true;
} else if (messageStarted) {
// Store the received byte in the buffer
receivedBytes[byteIndex] = receivedChar;
byteIndex++;
if (byteIndex == 4) {
// End of message; process the data
int highByteX = receivedBytes[0];
int lowByteX = receivedBytes[1];
int highByteY = receivedBytes[2];
int lowByteY = receivedBytes[3];
xValue = (int(highByteX) << 8) | lowByteX;
yValue = (int(highByteY) << 8) | lowByteY;
// Process the received values as needed
// Example: Print them to the Serial Monitor
// Serial.print("X: ");
// Serial.print(xValue);
// Serial.print("\tY: ");
// Serial.println(yValue);
speed = map(yValue, 0, 1023, -9.00f, 9.00f);
Serial.println(speed);
messageStarted = false; // Reset for the next message
motor1.loopFOC();
motor.move(speed);
motor1.move(speed);
this is my code for refference the output ramp function has no effect no matter how much I increase its value, can anyone help me?
