Hello all,
during implementing, I noticed that there are different orders for initializing current sense in the documentation. In the inline current sense documentation, the order is:
void loop(){
// driver init
// link the driver to the current sense
// motor init
// init current sense
current_sense.init();
// start the FOC
However, in the foc current mode description, the order is:
encoder.init();
motor.linkSensor(&encoder);// driver config
// link driver
motor.linkDriver(&driver);// current sense init hardware
motor.linkCurrentSense(¤t_sense);// set torque mode:
motor.controller = MotionControlType::torque;// initialize motor
// align sensor and start FOC
motor.initFOC()…
As you can see, in the second example, current_sense.init() is after motor.init() and current_sense.linkDriver(&driver) is not called.
Can someone explain why there is a difference? And which one is correct? Or does the order and current_sense.linkDriver(&driver) does not have any effect?
Thanks,
Alex
