Hi, my motor works OK with “pure voltage” and “voltage with current estimation” mode
When I try to use “Voltage control with current estimation and Back-EMF compensation” the behavior gets really strange.
As you can see from the attached session, when I command any positive current, the motor jumps right to full speed(~350 rad/s)… When I target 0 current, nothing happens!!!. As you can see from the log, Nothing happens until I comand about -1 A.
I’m fairly confident on the resistance and K-rating for the motor.,
Sensor: 100 PPR (400CPR) optical quadrature encode
Motor: 42BLS02
Controller: ST32G431 (NUCLEO)
DRIVER: 8302
enter setup…
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: OK!
MOT: Zero elec. angle: 6.22
MOT: No current sense.
MOT: Ready.
setup complete…
Warn: \r detected!
Monitor | downsample: 100000
0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -0.0157
Warn: \r detected!
0.100 ##### TARGET 0.1 A makes MOTOR JUMPS TO FULL SPEED!!1
0.1000 1.3800 0.0000 99.9571 0.0000 47.3901 24.0175
0.1000 9.0000 0.0000 -445.6520 0.0000 349.7160 931.4980
0.1000 9.0000 0.0000 -427.3739 0.0000 349.0393 2089.3476
0.1000 9.0000 0.0000 -450.4194 0.0000 349.8926 3249.9619
0.1000 9.0000 0.0000 -484.6363 0.0000 351.1594 4412.3984
Warn: \r detected!
0.000 ##### TARGET 0 A makes does NOT stop motor!!!
0.0000 9.0000 0.0000 -477.6773 0.0000 350.9018 5575.8085
0.0000 9.0000 0.0000 -460.1956 0.0000 350.2545 6738.4653
0.0000 9.0000 0.0000 -402.7777 0.0000 348.1287 7893.1103
0.0000 9.0000 0.0000 -408.9327 0.0000 348.3566 9048.0224
Warn: \r detected!
-0.100 **##### TARGET -0.1 A has has no effect!!!
-0.1000 9.0000 0.0000 -447.4249 0.0000 349.7817 10205.9199
-0.1000 9.0000 0.0000 -492.4383 0.0000 351.4483 11369.6601
-0.1000 9.0000 0.0000 -490.0589 0.0000 351.3602 12534.5312
Warn: \r detected!
-0.200
-0.2000 9.0000 0.0000 -479.4617 0.0000 350.9678 13697.2343
-0.2000 9.0000 0.0000 -483.3966 0.0000 351.1135 14859.1992
Warn: \r detected!
-0.500
-0.5000 8.7477 0.0000 -499.9228 0.0000 342.3880 16018.5419
-0.5000 8.7095 0.0000 -500.9279 0.0000 340.9717 17152.8300
-0.5000 8.7028 0.0000 -500.8154 0.0000 340.7238 18288.3730
Warn: \r detected!
-1.000 **##### TARGET -1 A finally motor starts to spin the other way
-1.0000 5.9253 0.0000 -999.9423 0.0000 256.4022 19285.1699
-1.0000 -0.4330 0.0000 -999.6849 0.0000 20.9912 19895.7695
-1.0000 -9.0000 0.0000 -337.9717 0.0000 -320.7031 18932.4628
-1.0000 -9.0000 0.0000 -322.8493 0.0000 -321.2631 17868.2636
-1.0000 -9.0000 0.0000 -338.9483 0.0000 -320.6670 16802.1171
Warn: \r detected!
-2.000
-2.0000 -9.0000 0.0000 -340.2853 0.0000 -320.6175 15735.8457
-2.0000 -9.0000 0.0000 -319.8786 0.0000 -321.3730 14670.1542
Warn: \r detected!
0.000
0.0000 -7.9956 0.0000 -0.5326 0.0000 -296.0299 13653.8642
Warn: \r detected!
0.000
0.0000 0.0000 0.0000 0.0006 0.0000 -0.0000 13213.9316
0.0000 0.0000 0.0000 0.0000 0.0000 -0.0000 13213.9316
0.0000 0.0000 0.0000 0.2292 0.0000 -0.0085 13213.9316
0.0000 0.0000 0.0000 -0.2724 0.0000 0.0101 13213.9628
0.0000 0.0000 0.0000 0.0001 0.0000 -0.0000 13213.9785
0.0000 0.0000 0.0000 0.0000 0.0000 -0.0000 13213.9785
Warn: \r detected!
Monitor | downsample: 0
#include “DRV8301.h”
MOTOR : 42BLS02
CTRLR : STM
ALGO : FOC-TORQU
DRIVE : DRV8302
SENS : ENCODER 100PPR
#define CONTROL_TYPE (MotionControlType::torque)
#define SUPPLY_V (18)
#define DRIVER_V_LIMIT (18)
#define MOTOR_V_LIMIT (9)
#define SENSOR_ALIGN_V (2) //1
#define USE_DRV8302
//#define USE_SMOOTHSENSOR
#ifdef USE_SMOOTHSENSOR
#include “smoothsensor.h”
#endif
#define HB_IO (8)
Encoder sensor = Encoder(14, 15, 100);
#ifdef USE_DRV8301
//DRV8301 gate_driver = DRV8301(PC13, PC14, PC15, PB7, PF0, PF1); // MOSI, MISO, SCLK, CS, EN_GATE, FAULT
DRV8301 gate_driver = DRV8301(3, 4, 5, 2, 6, 7); // MOSI, MISO, SCLK, CS, EN_GATE, nFAULT
#endif //USE_DRV8301
#ifdef USE_DRV8302
DRV8302 gate_driver = DRV8302(2, 3, 4, 5, 6, 7); // nFAULT, M_PWM, M_OC, GAIN, OC_ADJ, EN_GATE
#endif // USE_DRV8302
// motor & driver instance
//BLDCMotor motor = BLDCMotor(4); // works good
//BLDCMotor motor = BLDCMotor(4, 1); // works good
BLDCMotor motor = BLDCMotor(4, 1, 250); // strange behavior
BLDCDriver3PWM driver = BLDCDriver3PWM(PC0, PC1, PC2); // DRV8301/2
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
//void doC(){sensor.handleC();}
// void doMotor(char* cmd) { command.motor(&motor, cmd); }
void doTarget(char* cmd) {command.scalar(&motor.target, cmd);}
void doLimit(char* cmd) {command.scalar(&motor.voltage_limit, cmd);}
void doInduct(char* cmd) { command.scalar(&motor.phase_inductance, cmd); }
SmoothingSensor smooth = SmoothingSensor(sensor, motor);
#endif
char msgbuf[256];
Serial.begin(921600); // WARNING: low value like 115200 cause distorted FOC
// for timer analysis
//SimpleFOCDebug::enable(&Serial);
//delay(5000);
Serial.printf(“enter setup…\n”);
sensor.enableInterrupts(doA, doB /, doC/);
smooth.phase_correction = -_PI_6; // FOR HALL SENSOR
motor.linkSensor(&smooth);
#else // USE_SMOOTHSENSOR
#endif
driver.voltage_power_supply = SUPPLY_V;
driver.voltage_limit = DRIVER_V_LIMIT;
#ifdef USE_DRV8302
gate_driver.begin(PWM_INPUT_MODE_3PWM, SHUNT_GAIN_10);
_delay(100);
// link driver
motor.voltage_sensor_align = SENSOR_ALIGN_V;
//motor.controller = MotionControlType::torque;
motor.controller = CONTROL_TYPE;
motor.velocity_limit = 200;
motor.voltage_limit = MOTOR_V_LIMIT;
motor.current_limit = 1000.0;
// velocity loop PID
motor.PID_velocity.P = 0.1;
motor.PID_velocity.I = 0.05;
motor.PID_velocity.D = 0.0;
motor.PID_velocity.limit = 1000.0;
motor.LPF_velocity.Tf = 0.1;
// angle loop PID
motor.P_angle.P = 5.0;
motor.P_angle.I = 0.0;
motor.P_angle.D = 0.0;
motor.P_angle.output_ramp = 1000.0;
motor.P_angle.limit = 1000.0;
motor.LPF_angle.Tf = 0.0;
// motor.motion_downsample = 10;
motor.target = 0;
motor.monitor_downsample = 0; // disable intially
motor.monitor_variables = _MON_TARGET | _MON_VOLT_Q | _MON_VOLT_D | _MON_CURR_Q | _MON_CURR_D | _MON_VEL | _MON_ANGLE; // monitor target velocity and angle
//motor.foc_modulation = SpaceVectorPWM;
// initialise motor
command.add(‘T’, doTarget, “target”); // ssss space
command.add(‘I’, doInduct, “phase_inductance”);
command.add(‘M’,doMotor,“motor”);
Serial.printf(“setup complete…\n”);
pinMode(HB_IO, OUTPUT);
// motor monitoring
digitalWrite(HB_IO, 0);
#if defined(USE_DRV8301) || defined(USE_DRV8302)
if (gate_driver.is_fault())
sprintf(msgbuf, “gate driver faulted”);
