I’m using a Mini board, v. 1.0, small BDUAV 2204-260KV motor from Amazon, AMT103 encoder. I trying for target angle and have modified an example. When run I get movement, all in the same direction, four times and then the motor stops and is free wheeling, Any suggestions on where I need to look? Here’s my code.
// Test_SimpleFOC
// motor instance
BLDCMotor motor = BLDCMotor(7); // Pole pair number, half the number of poles
// driver instance
// BLDCDriver3PWM( int phA, int phB, int phC, int en)
// - phA, phB, phC - A,B,C phase pwm pins
// - enable pin - (optional input)
BLDCDriver3PWM driver = BLDCDriver3PWM(11, 10, 9, 8);
// encoder instance
// Encoder(int encA, int encB , int cpr, int index)
// - encA, encB - encoder A and B pins
// - ppr - impulses per rotation (cpr=ppr*4)
// - index pin - (optional input)
Encoder encoder = Encoder(2, 3, 2048);
// channel A and B callbacks
pinMode(12, OUTPUT);
digitalWrite(12, LOW);
encoder.init();
// Quadrature mode enabling and disabling
// Quadrature::ON - CPR = 4xPPR - default
// Quadrature::OFF - CPR = PPR
encoder.quadrature = Quadrature::OFF;
motor.linkSensor(&encoder);
// controller configuration
// velocity PID controller parameters
// default P=0.5 I = 10 D =0
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.PID_velocity.D = 0.001;
motor.current_limit = 1.0;
motor.LPF_velocity.Tf = 0.01;
// angle P controller - default P=20
motor.P_angle.P = 20;
// default 20
motor.velocity_limit = 4;
motor.voltage_limit = 10;
Serial.println(“Motor ready.”);
// angle set point variable
float target_angle = 1;
// timestamp for changing direction
long timestamp_us = millis();
// each one second
if(millis() - timestamp_us > 1000) {
// inverse angle
target_angle = -target_angle;
//target_angle += 0.1;
motor.move(target_angle);
// float position = encoder.getAngle();
// Serial.print("Position: ");
// Serial.println(position);
