Hi all,
I’m using a custom board with an ATmega328, DRV8313, and AS5600 to drive a BLDC motor and facing two issues:
- Noise during rotation: The motor produces a high-pitched sound, especially at mid to high speeds.
- Vibration at velocity 0: The motor vibrates significantly when trying to hold position.
I’m using a ROB-20441 motor from sparkfun with 7.5 ohms winding resistance and an 8V power supply.
Here’s my code:
BLDCDriver3PWM driver = BLDCDriver3PWM(3, 5, 6, 7);
float target_velocity = 10.0;
void doVelocity(char* cmd) { command.scalar(&motor.velocity_limit, cmd); }
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
// driver.voltage_limit = 7.4;
// driver.pwm_frequency = 20000;
// motor.motion_downsample = 10;
motor.PID_velocity.P = 0.3f; //0.4f
motor.PID_velocity.I = 10.0f; //1.0
// motor.PID_velocity.D = 0.01f;
motor.LPF_velocity.Tf = 0.001; //0.525f
motor.voltage_limit = 2;
motor.velocity_limit = 20;
motor.PID_velocity.output_ramp = 10000;
motor.zero_electric_angle = 6.14;
motor.sensor_direction = Direction::CW;
Serial.print("Sensor angle: ");
Thanks for your time and help!
No, it's only motor.voltage_limit that needs to be <0.58x. Driver limit is the total DC range you have to work in, and should generally be equal to voltage_power_supply (which is what it defaults to).
– dekutree64My bad, I was reading it too fast.
– Candas1
