Mt6816 with Spectral Micro BLDC driver
Hey guys!
We have a BLDC driver that we use with our custom-made FOC code and it works great. It uses STM32f103c and mt6816 magnetic encoder.
We figured we could use this hardware to support simpleFOC and have already implemented Open loop mode but have problems with mt6816 encoder. Did anyone use this encoder with STM32f103c that could share a snippet of code that works?
We would like to implement voltage torque mode and inline current torque mode since we know it works well with our own code.
#include "Arduino.h"
#include "SimpleFOC.h"
// Driver PWM pins
#define PWM_CH1 PA_2
#define PWM_CH2 PA_1
#define PWM_CH3 PA_0
// Encoder pins
#define MOSI PB_5
#define MISO PB_4
#define CLK PB_3
#define CSN PA_15
#define SENSE1 PA_4 // Inline current sense
#define SENSE2  PA_3 // Inline current sense
#define TX_COM PB_6
#define RX_COM PB_7
// Current sense resistors
#define SENSE_RESISTOR 0.025f
#define CURRENT_AMP_GAIN 20
// Serial pins
#define Serial Serialx
HardwareSerial Serialx(RX_COM, TX_COM); // PA3, PA2 RX,TX
// BLDCMotor motor = BLDCMotor(pole pair number, phase resistance (optional) );
//  BLDCDriver3PWM( pin_pwmA, pin_pwmB, pin_pwmC )
BLDCDriver3PWM driver = BLDCDriver3PWM(PWM_CH1, PWM_CH2, PWM_CH3);
//target variable
float target_velocity = 0.1;
void Init_pins();
  // Init driver enable pins and LED
  Init_pins();
  driver.pwm_frequency = 20000;
  driver.voltage_limit = 5;
  // driver init
  // init motor hardware
    // use monitoring with the BLDCMotor
  // monitoring port
  // monitoring function outputting motor variables to the serial terminal
void Init_pins(){
  pinMode(PA_9, OUTPUT);
	pinMode(PA_8, OUTPUT);
	pinMode(PA_10, OUTPUT);
	pinMode(PB_15, OUTPUT);
	pinMode(PB_14, OUTPUT);
	pinMode(PB_13, OUTPUT);
  digitalWrite(PA_9,HIGH);
  digitalWrite(PA_8,HIGH);
  digitalWrite(PA_10,HIGH);
  digitalWrite(PB_14, HIGH);
  digitalWrite(PB_15, HIGH);
  digitalWrite(PB_13, HIGH);
3
There is code for it in the drivers repository Arduino-FOC-drivers/src/encoders/mt6816 at master · simplefoc/Arduino-FOC-drivers · GitHub
Awesome, thank you for pointing this out. Valentine
Cool got it working with that first try. Will share the code here once it is on the GitHub. Cheers!
We did something similar, check this out.
At the very least you could modify the code and contribute?
Here is the example code that works, thanks guys:
