Motor Vibrates on achieving Angle position
Hi, i am using 42BLFX01E BLDC motor. 48v. I am using 24v supply. When i run position control it goes to angle and then it start moves forward and reverse slowly. Most of the time it does. What could be the issue. Motor has 8 poles. I tested hall Sensor example. It’ ok. Reduced motor.P_angle.P = 20; to 10 or 5. But it didn’t work.
3
Paste this in loop()
  // Don't try to stop between cogging steps
  if (motor.controller == MotionControlType::angle) {
    const float c = _PI_3/motor.pole_pairs;
    target = floor(target / c + 0.5f) * c;
It's just because of float values ?
Sensor resolution. If the target is inbetween two hall steps, the velocity integral error will gradually grow until the motor moves and hops over the target to the next hall step, and the cycle repeats.
Hey @MianSannan could you post your code? I probably can’t solve your problem, but it might help someone else.
Please see the code below.
#include <PciManager.h>
#include <PciListenerImp.h>
BLDCMotor motor = BLDCMotor(8);
// hall sensor instance
HallSensor sensor = HallSensor(2, 3, 4, 8);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
PciListenerImp listenC(sensor.pinC, doC);
// angle set point variable
float target_angle = 0;
  // initialize sensor hardware
  sensor.enableInterrupts(doA, doB); //, doC);
  // software interrupts
  PciManager.registerListener(&listenC);
  // aligning voltage [V]
  // contoller configuration
  motor.PID_velocity.P = 0.1f;
  motor.PID_velocity.I = 0.2;
  motor.voltage_limit = 12;
  motor.LPF_velocity.Tf = 0.001f;
  // angle P controller
  motor.velocity_limit = 4;
  // align sensor and start FOC
  motor.move(target_angle);
