I’m using simplefoc mini to control gimbal BLDC motor 2804 100T , encoder AS 5600 I2C (closed loop control example)
Motor init shaking (few months ago it’s not working like that)
I also checked encoder value no abnormal.
I want to ask if there’s no problem with my code, maybe the problem comes from the driver. Thanks!
Here is the code I used to test:
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
//MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 10);
BLDCMotor motor = BLDCMotor(7);//BLDC 2804 100T
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 5, 3, 8);// arduino nano
// angle set point variable
float target_angle = 0;
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 20;
// align sensor and start FOC
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
1 Answer
1The motor is shaking during motor.init() because the voltage and PID values are too high for a gimbal motor. Set motor.voltage_limit = 1.5 and motor.P_angle.P = 5 to fix the oscillation. If shaking persists, the SimpleFOC Mini driver may have been damaged over time and needs replacement.
