I could not set motor.motion_downsample. It is always zero (the default value) regardless how I set it in the setup(). I tried to put motor.motion_downsample = 2;
before motor.init()
before motor.initFOC()
after motor.initFOC()
in loop()
All failed. But I was able to set motor.monitor_downsample. Could someone help?
My setup
- MCU: Arduino Mega
- Driver: Simplefoc Shield V2.0.4
- Motor: T-motor gimbal motor
- Sensor: AS5047P
- Programming env: Arduino IDE
- Power supply: 3S Lipo
Code
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 53);
BLDCMotor motor = BLDCMotor(7, 14.4);
void onMotor(char* cmd){ commander.motor(&motor,cmd); }
driver.voltage_power_supply = 11.5;
motor.target = 0;
motor.monitor_downsample = 120;
// motor.motion_downsample = 2;
commander.add('M',onMotor,"my motor motion");
commander.run();
Serial monitor output
