Motor keeps spinning in whatever direction you spin it in
I’ve been trying to get this library working on a teensy 4.1 with a SimpleFOC Mini and an AS5147U magnetic sensor, but i’ve been experiencing a few issues:
At first the motor was making a high pitch squealing sound; the only thing that fixed this was manually setting the PWM frequency of each pin with analogWriteFrequency to 25000 like in src/drivers/hardware_specific/teensy/teensy_mcu.h.
When I tried to use torque control, the motor would do nothing at all no matter what value I passed to move(). If I manually moved the motor, it would keep moving in that direction (the torque can be at 0). While the motor was moving, I could change its direction by setting the torque, but if I stopped it, I had to manually restart it. video
This is my code:
// init BLDC motor
BLDCMotor motor = BLDCMotor(7, 5.6, 160);
// init driver
BLDCDriver3PWM driver = BLDCDriver3PWM(3, 4, 5, 2);
//  init encoder
// target variable
float target = 0;
// commander interface
void onTarget(char* cmd){ command.scalar(& target, cmd); }
  delay(2000);
  analogWriteFrequency(3, 25000);
  analogWriteFrequency(4, 25000);
  analogWriteFrequency(5, 25000);
  sensor.clock_speed = 10000000;
  // power supply voltage
  // default 12V
  driver.pwm_frequency = 25000;
  // link the motor to the driver
  // set control loop to be used
  //default voltage_power_supply
  motor.voltage_limit = 2;
  command.add('T', onTarget, "target");
  motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE;
  _delay(5000);
  // iterative FOC function
  // function calculating the outer position loop and setting the target position
  motor.move(target);
I also tried velocity_openloop, which worked well, and velocity, which had similar issues as torque.
Most likely the kv passed to the BLDCMotor constructor needs tuning. Add a command to change motor.KV_rating and fiddle it up and down until it acts right. This is using voltage-based current limiting to apply a constant torque regardless of speed, so an un-loaded motor should accelerate to full speed even if the target is fairly small. But target 0 should still stop moving.
Are you sure the sensor is working as expected? you could print the sensor value without any of the motor and driver code to verify its functionality.
This solved it! I had previously just trusted the manufacturer’s 160 KV rating, but when I calculated it, it was more like 335. Thanks!
Ive printed it out using the monitor, but it looks correct. The position goes up by a bit over 6 radians every rotation.
