Hi!
TLDR;
motor.initFOC() does not activate PWM. The motor does not spin and the Index search fails. Why? Did I miss something?
Used hard and software
- Board: ST Discovery B-G431B-ESC1
- Motor: Maxon EC 45 250 W
- Arduino IDE 2.3.8
- SimpleFOC lib 2.4.0
- PSU 24 V, 5 A
What did I test?
1. Sensor test - OK
I tested successfully the SimpleFOC Sensor test <https://docs.simplefoc.com/test_sensor>.
I changed the following lines from the example:
Encoder encoder = Encoder(A_HALL1, A_HALL2, 500, A_HALL3); // adjusted to my encoder
void doIndex(){encoder.handleIndex(); // line added
encoder.enableInterrupts(doA, doB, doIndex); // doIndex added
Serial.println(encoder.getVelocity()); // error in example - to use sensor make no sense here
With these changes the example works like a charm. I turn the rotor manually and get two numbers in the serial console. The first number counts up (or down - dependent of the direction I turn the rotor) and the seconds shows the velocity.
2. Driver test - OK
I tested successfully the SimpleFOC driver test <https://docs.simplefoc.com/test_driver>.
driver.voltage_limit = 8;
With these changes I got the example running. Without the motor connected I got:
- phase U: 3.06 V
- phase V: 6.12 V
- phase W: 5.09 V
I also tested the second part with the dynamic PWM. It worked, too.
3. Open loop motor - driver test - OK
I tested successfully the SimpleFOC open loop motor driver <https://docs.simplefoc.com/test_motor_driver>.
BLDCMotor motor = BLDCMotor(1, 0.336, 224, 0.000149, 0.000149); // all values from the datasheet
driver.voltage_power_supply = 24; // same as test #2
driver.voltage_limit = 8; // same as test #2
motor.voltage_limit = 2;
No problems. The motor spins with 60 rpm or 6.28 rad/s. I can see all three PWM on the scope.
4. Closed Loop test - Failed
So far I have a working encoder, driver and motor. But together I can’t get it to work. The closed loop example <https://docs.simplefoc.com/test_closedloop> fails.
BLDCMotor motor = BLDCMotor(1, 0.336, 224, 0.000149, 0.000149); // same as test #3
BLDCDriver6PWM driver = BLDCDriver6PWM(A_PHASE_UH, A_PHASE_UL, A_PHASE_VH, A_PHASE_VL, A_PHASE_WH, A_PHASE_WL); // same as test #3
Encoder encoder = Encoder(A_HALL1, A_HALL2, 500, A_HALL3); // same as test #1
void doIndex(){encoder.handleIndex(); // same as test #1
encoder.enableInterrupts(doA, doB, doIndex); // same as test #1
driver.voltage_power_supply = 24; // same as test #3
driver.voltage_limit = 8; // same as test #3
Log from the start:
TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: best: TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: Initializing TIM1
STM32-DRV: Timer resolution set to: 3400
STM32-DRV: Configured TIM1_CH1
STM32-DRV: Configured TIM1_CH2
STM32-DRV: Configured TIM1_CH3
STM32-DRV: Synchronising 1 timers
MOT:Monitor enabled!
MOT:Init
MOT:Enable driver.
MOT:Align sensor.
MOT:Index search...
ERR-MOT:Not found!
ERR-MOT:Init FOC fail
FOC init failed!
You can see the index is not found. I can’t see any PWM during the Index search period. The scope shows only flat lines around 0 V.
Did I miss something? Any help would be appreciated.
Trivia: If I turn the rotor manually during the index search period. The index is found and everything comes to live. The motor spins and I can control the voltage via serial commands.
5. Bonus: B-G431B-ESC1 example - failed
I found in the Arduino IDE a B-G431B-ESC1 example
- File →
- Examples →
- Simple FOC →
- Hardware_specific_examples →
- B_G431B_ESC1.
- Simple FOC →
- Examples →
I changed the following lines to match my hardware and tested it:
motor.velocity_index_search = 2;
The example uses motor.initFOC(), too. So it failed in the same way as in example #4. No PWM during the index search, flat lines on the scope → init failed.
I hope someone has an idea why initFOC does not send a PWM to the motor.
Best regards,
Tom
