We have been discussing the awesome MKS XDrive Mini boards form Makerbase for some time now. They are really inexpensive and have awesome characteristics.
Real-time timer based FOC (loopFOC at 20khz and move at 4kHz)
I’ve also included some CAN communication examples for those that want to use it in the can_scripts section.
This is an amazing board. It could be a much more robust alternative to the B-G431B-ESC1.
So yeah, if someone wants to use it with SimpleFOC and not Odrive firmware this repo is a good starting point.
Been waiting for this these boards to get some traction! I have a MKS_S, did you have any issues with the DRV8301 init? I struggled to get the shunt gain to actually apply successfully, ended up with this mess! But it works , curious if your implementation is enough to keep it simple
I did modify the gain to 80 in my code. Increased it quite a bit, to make it more smooth with my motor.
I am not sure that the way I did it is the best way but it should work
I’m pretty sure I did test it. I dont have the setup with me now so I cannot confirm 100%.
But I’m pretty sure I did test it
Yeh okay! I might dust off my board and test your way. Keen to try out the Mini, just need a project to use it on. No issue with encoder? There were comments on the SFOC forums a while back that noise was an issue which originally steered me away from it.
I was testing my motor with 10+ amps of current and the board suddenly browned out and restarted, and in a few seconds it started smoking. Is there an explanation for this? Could it be a glitch in the mosfets causing a short circuit in the short time it browned out.
