Hi everybody.
I have a axial flux motor that is mentioned in spec that the KV rating is 7 RPM/Volt.
But when I use SimpleFoc in FOC_Current mode and the source is 12 volt the below scenario is happened :
1- The motor reaches Target = 6 ( velocity rad/s ) and Vq does not reach maximum voltage and everthings is good and drive tries to control motor in desired velocity.
2- When we set Target = 7 the motor can not reach this velocity and Vq sticking to maximum and it does not what I expected.
This scenario happens with different voltage source and higher Target.
For example with 24V , motor can reach T=11 and everything is good but when I set T=12 Vq sticking to max.
Is there any parameter that should I change ?
My code is here :
HardwareSerial Serial2(PB11, PB10);
/// F103 TIM1
// #define PHA_H PA8 // TIM1
// #define PHA_L PB13 // TIM1
// #define PHB_H PA9 // TIM1
// #define PHB_L PB14 // TIM1
// #define PHC_H PA10 // TIM1
// #define PHC_L PB15 // TIM1
/// F407VGT6 TIM1
#define PHA_H PE9 // TIM1
#define PHA_L PA7 // TIM1
#define PHB_H PE11 // TIM1
#define PHB_L PB0 // TIM1
#define PHC_H PE13 // TIM1
#define PHC_L PB1 // TIM1
// magnetic sensor instance - AS5600 I2C
// MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
// /SPI 1 (AS5048A)
#define MOSI_ENC PB5// PA7
#define MISO_ENC PB4// PA6
#define CLK_ENC PB3// PA5
#define CS_ENC PE3
// MagneticSensorSPIConfig_s AS5048A_SPI_Config{
// .spi_mode = SPI_MODE1,
// .clock_speed = 10000000,
// .bit_resolution = 14,
// .angle_register = 0x3FFF,
// .data_start_bit = 13,
// .command_rw_bit = 14,
// .command_parity_bit = 15
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, CS_ENC);
SPIClass SPI_1(MOSI_ENC, MISO_ENC, CLK_ENC); //(mosi, miso, sclk)
BLDCMotor motor = BLDCMotor(5);
// BLDCMotor motor = BLDCMotor(5);
BLDCDriver6PWM driver = BLDCDriver6PWM(PHA_H, PHA_L, PHB_H, PHB_L, PHC_H, PHC_L);
// InlineCurrentSense current_sense = InlineCurrentSense(16.33f, PA0, PA1, PA2);
InlineCurrentSense current_sense = InlineCurrentSense(31.3f, PA0, PA1, PA2);
float target_velocity = 0;
// Commander command = Commander(Serial1);
Commander command = Commander(Serial2);
// void doMotor(char* cmd) { command.motor(&motor, cmd); }
sensor.init(&SPI_1);
motor.phase_inductance = 0.25;
motor.KV_rating = 7.17;
// motor.zero_electric_angle = 5.06;
// motor.sensor_direction = Direction::CCW;
motor.zero_electric_angle = 2.12;
// motor.zero_electric_angle = 1.90;
// motor.sensor_direction = Direction::CW;
driver.voltage_limit = 22;
motor.voltage_limit = 22;
driver.pwm_frequency = 32000;
driver.dead_zone = 0.05;
// current_sense.gain_b *=-1;
// current_sense.skip_align = true;
current_sense.init();
// current_sense.gain_a *=-1;
// current_sense.gain_c *=-1;
motor.voltage_sensor_align = 6;
// motor.controller = MotionControlType::velocity;
motor.modulation_centered =1;
motor.motion_downsample = 10;
// contoller configuration
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.LPF_velocity.Tf = 0.05f;
motor.LPF_angle.Tf = 0.05f;
motor.PID_current_q.P = 0.15;
motor.PID_current_q.I= 0.6;
// motor.PID_current_q.limit = motor.voltage_limit;;
motor.PID_current_d.P= 0.15;
motor.PID_current_d.I = 0.6;
// motor.PID_current_d.P= 0.001;
// motor.PID_current_d.I = 0.001;
// motor.PID_current_d.limit = motor.voltage_limit;;
motor.LPF_current_q.Tf = 0.005f;
motor.LPF_current_d.Tf = 0.005f;
// motor.phase_resistance = 0.25;
motor.current_limit = 20; // 36V
Serial2.begin(115200);
// command.add('A', doMotor, "motor target");
// command.add('A',doMyMotor,"my motor");
motor.useMonitoring(Serial2);
// motor.monitor_downsample = 0;
// align sensor and start FOC
// command.add('M', doMotor, "Motor");
// motor.monitor_downsample = 100;
Serial2.println(F("Motor ready."));
Serial2.println(F("Set the target velocity using serial terminal:"));
