I am trying to tune a BLDC motor we have (iPower GM110-8), the motor is interfaced with AS5048-A magnetic sensor and i am using the PWM output of the sensor. I am using an STM32 Nucleo-64 (F446RE) board with SimpleFOC shieled 2.0.4 shield.
The motor works fine and smooth in open loop position and velocity examples. But when i switch to closed loop torque control mode with Torque control technique as Voltage, the motor starts being jittery in its movement and starts making soound, This jittery movement is observed in the angle graph as well when seen through Simple FOC studio. ( kindly refer to the snap below):
I have tried a few things like, trying to get the sensor data via SPI and using STM32 based pwm libraries, but not to much success.
Could you provide me with insights into solving this problem?
