Hi @runger ,
thank you for your replay
yesterday I tried to solder the 4 contacts for GND, 5V and the two for I2C. It is horror and not practical. I sat for an hour The contacts are about 1mm wide and 1mm apart there. canât do it at all. i think i also created a short, but i canât check it with the naked eye. nevertheless i tested the sensor and lo and behold. it seems to work for now:
// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
// chip_address - I2C chip address
// bit_resolution - resolution of the sensor
// angle_register_msb - angle read register msb
// bits_used_msb - number of used bits in msb register
MagneticSensorI2C as5600 = MagneticSensorI2C(0x36, 12, 0x0E, 4);
// or quick config
// MagneticSensorI2C as5600 = MagneticSensorI2C(AS5600_I2C);
// monitoring port
// init magnetic sensor hardware
as5600.init();
Serial.println("AS5600 ready");
// IMPORTANT - call as frequently as possible
// update the sensor values
as5600.update();
Serial.print(as5600.getAngle());
Serial.print("\t");
Serial.println(as5600.getVelocity());
why the right numbers jump like this i donât know.
i have now ordered the white as5600 encoder and try my luck with the board. i have read here in the forum that the resistor R1 must be desoldered so that i can operate this encoder with 5V instead of 3.3V and the OUT must be grounded.
closed loop has not worked yet. the motor only hums. but with the other sensor and more space to solder it should be better.
// motor instance, number of pole pairs, not poles
// driver instance, must use 6PWM FOR B-G431 driver
BLDCDriver6PWM driver = BLDCDriver6PWM(PHASE_UH, PHASE_UL, PHASE_VH, PHASE_VL, PHASE_WH, PHASE_WL);
// Magnetic sensor instance
// buttom config
const int buttonPin = PC10;
int lastState = 0; // last button state
long timestamp = millis(); // timestamp
int direction = 1; // 1 or -1
// gear
float i = 200;
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// initialize magnetic sensor hardware
driver.voltage_power_supply = 9;
// velocity PID controller parameters
// default P=0.5 I = 10 D =0
motor.PID_velocity.P = 0.5;
motor.PID_velocity.I = 10;
motor.PID_velocity.D = 1;
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.0005;
// since the phase resistance is provided we set the current limit not voltage
// default 0.2
motor.current_limit = 1; // Amps
// motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE;
// downsampling
// motor.monitor_downsample = 100; // default 10
// align sensor and start FOC
// Serial.println("Motor ready.");
// Serial.println("Sensor ready.");
// motor.move(analogRead(POTENTIOMETER)/i*direction);
motor.move(2);
// buttom change direction
long deltaT = millis() - lastState;
if (deltaT>=500) {
int buttonState = digitalRead(buttonPin);
if (buttonState!=lastState) {
lastState = buttonState;
if (buttonState==1)
direction = direction * -1;
sensor.update();
// Serial.println(sensor.getAngle());
// Serial.print("\t");
// Serial.println(sensor.getVelocity());
Hi together,
update:
I have managed the closed loop with the as5600 and the B-G431B-ESC1. The direction of rotation and the speed can also be set. Unfortunately, the board is still very warm and I think there is no temperature difference to open loop. What could help to get the temperature down?
Furthermore, the motor does not rotate 100% smoothly, there is a kind of chatter. Could this be due to the settings? Super is that the engine is absolutely quiet and you hear no noise.
the direction of my motor sensor combination is âDirection::CCWâ
But I dont know the âoffsetâ and I have read in the forum, that a have to use the tool
âfind_zero_offset_and_directionâ
Where can I find it? I use Arduino IDE
If you run initFOC() without these parameters, it will perform the alignment and print the electrical angle found⌠You can then store the value, and use it to set the zero angle so the alignment can be skipped.
Oh, and to do it all programmatically, you can read the alignment value from motor.zero_electric_angle.
I noted your comment that the board was getting hot - but for the motor you are using, with no load and in closed loop mode, there should be almost no current flowing⌠My PSU shows somewhere between 0.00 and 0.10 amps when running such motors unloaded. So really, the B-G431B-ESC1 with its custom FETs should not get hot at all⌠is it the FETs getting hot, or some other part of the board?
So I wonder what is going on?
Open-Loop mode is a lot less efficient than closed loop, so in open loop I would expect a certain amount of heat, but again, not much with this motor. Also, if the alignment for FOC mode runs, but cannot find the electrical angle reliably. Or if the magnet were to slip a little bit out of position after the alignment⌠things like this could adversely affect the FOC performance, and cause more heat.
these are in the upper picture the black parts of the board where the motor is soldered.
I have set the lowpass filter to 0,05 to reduce fully the motor vibration. When I set the LF to 0, the engine vibrates a lot. does this seem to be an indication that the as5600 sucks? Perhaps this is where the high load from the board comes from
Yeah, the 6 bigger components near the motor leads are the FETs which switch the power. These are normally what gets hot, but normally not unless youâre using significant power.
Yes, the AS5600 does suck
But the LPF is probably needed for any magnetic sensor - due to sampling effects and latencies the velocity has to be smoothed somewhat to make it useful. Tuning this parameter can be quite helpful sometimes. The value is somewhat linked to the main loop iteration speed and the motor.motion_downsample value. These factors determine how often the velocity gets computed, and therefore how much smoothing is needed.
do you know a good sensor board with pullups that is flat (less than 4mm) and costs less than 10euros that can do I2C and if the B-G431B-ESC1 board can do SPI (unfortunately I donât know) also SPI?
You should avoid I2C sensors if possible. The slow speed of I2C will certainly limit your performance, it will become the limiting factor of the whole system.
I looked into this recently, and the B-G431B-ESC1 canât do SPI, unfortunately.
The way I see it, the best options for precise sensors are a SSI interface (like SPI but with only 3 lines) or a ABZ interface. The MT6701 might be an option that can work for you, itâs fairly cheap and has loads of interfaces: I2C, SSI, ABZ, Analog and UVW, all in one sensorâŚ
Otherwise there are other SSI sensors from AMS, like the AS5045, IIRC. The AS5048A also has a 3-wire mode, but typically costs more than $10.
I should also mention that while Iâve tried these sensors in other setups, I havenât tried them with the B-G431B-ESC1 myself, so youâd be doing some experimentation hereâŚ
For ABZ mode, if the second picture can be trusted, you might have change something on the sensor PCB - remove a resistor or add one. Then you can connect the ABZ outputs to any available pins, and use the Encoder class of SimpleFOC as the sensor.
For SSI mode, the same pins are used as I2C, but presumably something has to be changed on the PCB to activate this.
For I2C mode, the intialization should work with: MagneticSensorI2C sensor = MagneticSensorI2C(0x6, 14, 0x03, 8);
But the MagneticSensorI2C class will try to do a 2-byte read, while the datasheet for the sensor suggests it wants 2 x 1-byte read, to consecutive registers. So I doubt it will work as is.
Iâm actually working on a driver for the MT6701, let me see if I can get the I2C mode supported.
Can you perhaps send pictures of both sides of the sensor board you have? Do you have more than one of them? It seems on this board you have to switch modes by setting solder bridgesâŚ
hi runger,
ok, thanks!
exactly, it says that you have to short the IIC bridge so you can use the I2C or ABZ. I bought 2 of this sensors that I usually do because one could always break and I donât want to wait a month for a new one.
I have now installed the following setting on my board. can you quickly look over there, whether from the settings goes out, whether there is something wrong, because the card is so warm? I would like to exclude that. By setting the correct offset, I could also take the LF further down and the engine runs not bad at all.
// buttom config
// gear
float i = 175;
motor.PID_velocity.P = 0.7;
motor.voltage_limit = 9;
motor.LPF_velocity.Tf = 0.05;
// default 0.2
// Serial.begin(115200);
// motor.useMonitoring(Serial);
motor.initFOC(PI/100*18, Direction::CCW);
delay(100);
if (deltaT>=500) {
if (buttonState==1)
// sensor.update();
I got the jerking as good as gone by setting âmotor.PID_velocity.P = 0.2;â
to âmotor.PID_velocity.P = 0.7;â, at 0.8 it starts to oscillate briefly when turned on.
One thing I think see is that you have to set the motor.phase_resistance if you want to set a motor.current_limit. Without the phase resistance value, you can only set a motor.voltage_limit.
Good to hear it is working better!
You can limit the motor velocity and ramp value, in effect limiting acceleration, but to do acceleration ramps, you will have to write additional software. I think people have found that it works well to modify the target value (i.e. model the motion pattern in the move() loop) rather than messing with the PID controller.
In my work on SimpleFOC I have used all the MCU type we support, except the Arduino Due, I donât have one. I donât use the 8 bit ATmega MCUs much any more for SimpleFOC, theyâre not really powerful enough.
The ones I use most often are STM32, SAMD and ESP32⌠but some of the others are pretty cool too. It all depends what your application is.
For sensors, I like the magnetic sensors for their small size and ease of use. I have experimented with a large number of them (see our drivers repository) and most of them work very well. Depending on your application SPI, SSI or ABZ interfaces are probably best. I2C is too slow.
And for motors, I have a huge amount of different (mostly cheap) BLDC motors I use to test SimpleFOC. For my use cases small outrunner gimbal type motors are what I use most, but I never have any time to work on my projects at the moment
Have you ever worked on the skateboard motor that has built-in Hall sensors? During my testing, I found that while applying load to the motor, the electric sector of the Hall sensor toggled between two values causing vibration in the motor and a lot of noise.
Was wondering instead of the hall sensor if any other position sensor is introduced, will it solve this problem?
HallSensor is quite âroughâ compared to other sensor types, and toggling between two values would lead to large âstepsâ in the angle output - presumably with correspondingly large response from the controller. A more precise sensors would lead to a smoother angle output and, presumably smoother response from the controller.
But in a stall situation, thatâs not an expected situation for the SimpleFOC code, so I think in this situation there can be noise with any sensor type, as the controller increases the torque to try to get the motor moving.
