Hi all! First post, love the community and project.
I’m working on getting inline current sense working on a esp32 (specifically esp32-s3-devkitc-1, this one here).
I’m seeing some odd behavior with the InlineCurrentSense constructor.
The following code fails (using just defines for the pins):
#define CURRENT_SENSE_A 6 // GPIO6 - ADC1_5
#define CURRENT_SENSE_B 7 // GPIO7 - ADC1_6
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50, CURRENT_SENSE_A, CURRENT_SENSE_B);
results in:
Starting...
ESP32-DRV: Configuring 3PWM in group: 0 on timer: 0
ESP32-DRV: Configuring 2 operators.
ESP32-DRV: Configuring 3 comparators.
ESP32-DRV: Configuring 3 generators.
ESP32-DRV: Configuring center-aligned pwm.
ESP32-DRV: Enabling timer: 0
ESP32-DRV: MCPWM configured!
MOT: Monitor enabled!
[ 1012][E][esp32-hal-gpio.c:113] __pinMode(): Invalid IO 50 selected
ESP32-CS: ERROR: Not ADC pin: 50
ESP32-CS: ERROR: Failed to initialise ADC pin: 50, maybe not an ADC pin?
Current sense init failed!
However, specifying pins directly in the constructor works:
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0f, 6, 7);
results in:
Starting...
[ 1012][E][esp32-hal-adc.c:172] __analogChannelConfig(): Pin is not configured as analog channel
[ 1021][E][esp32-hal-adc.c:172] __analogChannelConfig(): Pin is not configured as analog channel
Current sense init success!
casting to int also works:
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0f, (int)CURRENT_SENSE_A, (int)CURRENT_SENSE_B);
I feel like there’s a cpp thing going on that I don’t understand or I missed something in the docs.
Full code is here:
#include <Wire.h>
#define I2C_SDA 4 // SDA on encoder (encoder yellow)
#define I2C_SCL 5 // SCL on encoder (encoder orange)
#define PWM_A 15 // 9 on simplefoc shield v2 (red)
#define PWM_B 16 // 5 on simplefoc shield v2 (orange)
#define PWM_C 17 // 6 on simplefoc shield v2 (yellow)
#define ENABLE 18 // 8 on simplefoc shield v2 (green)
BLDCDriver3PWM driver = BLDCDriver3PWM(PWM_A, PWM_B, PWM_C, ENABLE);
// InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0f, CURRENT_SENSE_A, CURRENT_SENSE_B); // fails
// InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0f, 6, 7); // Direct pin numbers - works
float target_velocity = 0.0f;
void doTarget(char* cmd) {
command.scalar(&target_velocity, cmd);
// Serial.print("Target velocity set to: ");
// Serial.println(target_velocity);
Serial.println("Starting...");
Wire.begin(I2C_SDA, I2C_SCL);
Wire.setClock(400000);
sensor.init(&Wire);
if(!driver.init()){
return;
motor.PID_velocity.P = 0.04f;
motor.PID_velocity.I = 0.7f;
motor.PID_velocity.D = 0.0f;
motor.voltage_limit = 12; // [V]
motor.velocity_limit = 1000; // [rad/s]
motor.voltage_sensor_align = 1; // [V]
// init current sense
if (current_sense.init()) Serial.println("Current sense init success!");
else{
Serial.println("Current sense init failed!");
return;
// driver.pwm_frequency = 20000;
Serial.println(driver.pwm_frequency);
Serial.print("Current sense pins: ");
Serial.print(CURRENT_SENSE_A);
Serial.print(", ");
Serial.println(CURRENT_SENSE_B);
if(!motor.init()){
return;
command.add('M', doMotor,"my motor");
//motor.monitor();
motor.move(target_velocity); // use the target velocity here
// columtarget, voltage.q, velocity, angle
PlatformIO config:
[env:esp32-s3_i2c_simplefoc]
build_src_filter = +<esp32-s3_i2c_simplefoc.cpp>
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
board_build.mcu = esp32s3
board_build.f_cpu = 240000000L
board_build.partitions = default_8MB.csv
board_build.arduino.memory_type = qio_qspi
build_flags =
-DARDUINO_USB_MODE=1
-DARDUINO_USB_CDC_ON_BOOT=1
-DBOARD_HAS_PSRAM
upload_protocol = esptool
monitor_speed = 115200
lib_deps =
askuric/Simple FOC@^2.3.4
Wire
