I am working with Adafruit ESP32 S3, AS5048B and SimpleFOC board with a gimbal motor. So far I have tested the sensor to work perfectly. The moment I do motor.initFOC, my computer don’t even see the any USB devices anymore. USB communication with ESP32 stops. What am I doing wrong?
#include <Wire.h>
// Define the sensor object for AS5048B
// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
MagneticSensorI2C sensor = MagneticSensorI2C(0x44, 14, 0xFE, 8);
// My motor is a BDUAV-2204-260kv, a little gimbal motor, 7 pole pairs,
// phase resistance = 10 ohms
BLDCMotor motor = BLDCMotor(7, 10);
// Motor driver and initialization
BLDCDriver3PWM driver = BLDCDriver3PWM (5, 6, 9, 10); // Pins for the motor driver
driver.voltage_power_supply = 12; // driver config
driver.init(); // power supply voltage [V]
sensor.init(); // Initialize the sensor
motor.linkSensor(&sensor); // link the sensor to the motor
motor.linkDriver(&driver); // link the driver to the motor
// aligning voltage
// choose FOC modulation
// set torque mode
// align sensor and start FOC
//motor.initFOC();
delay(1000);
// target voltage to be set to the motor
float target_voltage = 2;
// Update sensor reading
sensor.update();
// Output angle
Serial.print("Angle (rad): ");
Serial.print(" | Velocity (deg/s): ");
Serial.println(sensor.getVelocity()); // Output velocity
//motor.loopFOC();
//motor.move(target_voltage);
delay(1000); // update rate
