Inductance: request for help with wiring
using simpleFOC shield
what are the wiring connections 10,5,6 I assume are for BLDC pwm connections, (but are 8 A0 & A2 needed?) for the inductance and phase resistance code from this page:
This code is not complete:
This discussion was most unhelpful and assumes rather a lot:
1 Answer
1
Yeah, you need current sense (A0, A2) to be able to determine the inductance and phase resistance. Pin 8 is for the motor enable.
Thank you for that confirmation. In addition, please could you suggest appropriate wiring? ie what to connect? The SensorlessFOC project page does not provide a diagram: https://docs.simplefoc.com/sensorless_foc_nucleo_example and the current sense pages are rather general, without working examples: https://docs.simplefoc.com/low_side_current_sense https://docs.simplefoc.com/inline_current_sense
