High Pitch Whine from Motor
Hi Folks,
I’m using the DRV8302 board to drive an AC servo motor in closed loop mode with current control. I’m using a Nucleo64 F401RE with SimpleFOC 2.2.2. I’ve used this combination in the past, but I’m now working from PlatformIO for development. When the motor is in use, it emits a whine whose volume is dependent on load/Iq current. In the past when building from the Arduino IDE, I’ve used this exact combination before, with no audible whine from the motor. I measured the frequency, and it’s almost exactly1 khz.
I’ve tried changing the PWM frequency, but that doesn’t have any effect. I also measured the loop time, and measured ~300 uS per loop.
Curious if anyone else has heard this noise before. Other than the noise, the motor and controller perform flawlessly.
I had the same problem, following the debugger found it was using generic pwm code and not stm32 specific, which wasn’t effective.
@runger pointed me to the solution:
If you are using PIO if lib_archive = false is not set in platformio.ino it will not use stm32 specific includes.
Ciao!
Hey @deffie, thanks for the note. I did not have lib_archive = false in my platform.ini file. When I added it however, the SimpleFOC startup procedure doesn’t work anymore, the motor and controller do not initialize (but compilation succeeds).
@runger Any ideas here? If helpful I can paste my code.
Code would help! And the ini too. Oh and do a clean build before.
Thanks! I did a clean build, but that didn’t work.
Below is the .ini file:
;   Build options: build flags, source filter
;   Upload options: custom upload port, speed and extra flags
[env:nucleo_f401re]
platform = ststm32
board = nucleo_f401re
framework = arduino
monitor_speed = 115200
lib_archive = false
lib_deps =
  # RECOMMENDED
  # Accept new functionality in a backwards compatible manner and patches
  https://github.com/simplefoc/Arduino-FOC.git#v2.2.2
And my code:
// DRV8302 pins connections
//#define INH_A PA8
//#define INH_B PA9
//#define INH_C PA10
#define INH_A PB13
#define INH_B PB14
#define INH_C PB15
#define EN_GATE PB7
#define M_PWM PB4
#define M_OC PB3
#define OC_ADJ PB6
#define OC_GAIN PB5
#define IOUTA A0
#define IOUTB A1
#define IOUTC A2
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
// DRV8302 board has 0.005Ohm shunt resistors and the gain of 12.22 V/V
LowsideCurrentSense cs = LowsideCurrentSense(0.005f, 12.22f, IOUTA, IOUTB, IOUTC);
// encoder instance
Encoder encoder = Encoder(PB8, PB9, 2048);
// channel A and B callbacks
// commander interface
  encoder.init();
  motor.linkSensor(&encoder);
  // DRV8302 specific code
  // M_OC  - enable overcurrent protection
  pinMode(M_OC,OUTPUT);
  digitalWrite(M_OC,LOW);
  // M_PWM  - enable 3pwm mode
  pinMode(M_PWM,OUTPUT);
  digitalWrite(M_PWM,HIGH);
  // OD_ADJ - set the maximum overcurrent limit possible
  pinMode(OC_ADJ,OUTPUT);
  digitalWrite(OC_ADJ,HIGH);
  pinMode(OC_GAIN,OUTPUT);
  digitalWrite(OC_GAIN,LOW);
  driver.pwm_frequency = 18000; // suggested under 18khz
  cs.linkDriver(&driver);
  // align voltage
  motor.voltage_sensor_align = 2.0;
  // control loop type and torque mode
  motor.motion_downsample = 0.0;
  // velocity loop PID
  motor.PID_velocity.P = 0.2;
  motor.PID_velocity.I = 5.0;
  motor.LPF_velocity.Tf = 0.02;
  // angle loop PID
  motor.P_angle.P = 20.0;
  motor.LPF_angle.Tf = 0.0;
  // current q loop PID
  motor.PID_current_q.P = 3.0;
  motor.PID_current_q.I = 100.0;
  motor.LPF_current_q.Tf = 0.02;
  // current d loop PID
  motor.PID_current_d.P = 3.0;
  motor.PID_current_d.I = 100.0;
  motor.LPF_current_d.Tf = 0.02;
  // Limits
  motor.velocity_limit = 100.0; // 100 rad/s velocity limit
  motor.voltage_limit = 12;   // 12 Volt limit
  motor.current_limit = 1.0;    // 2 Amp current limit
  // monitoring port
  motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // monitor the two currents d and q
  motor.monitor_downsample = 0;
  // initialise motor
  cs.init();
  // driver 8302 has inverted gains on all channels
  cs.gain_a *=-1;
  cs.gain_b *=-1;
  cs.gain_c *=-1;
  motor.linkCurrentSense(&cs);
  motor.target = 0;
  // define the motor id
  Serial.println(F("Full control example: "));
  Serial.println(F("Run user commands to configure and the motor (find the full command list in docs.simplefoc.com) \n "));
  Serial.println(F("Initial motion control loop is voltage loop."));
  Serial.println(F("Initial target voltage 2V."));
  // monitoring the state variables
The only thing I can maybe think of is that I am using slightly different PWM pins for INH_A, INH_B, and INH_C. I am connecting them to PWM/1N, PWM1/2N, and PWM1/3N on the Nucleo. I’m not sure what the “N” means on the PWM description…
Thank you!!
Check here for pwm pins explanation
Looks like they are interdependent, better/easier if you pick independent pwm channels eg. different first numbers
And I would use STM pin/port naming for analog channels too
The rest of the code looks ok to me
Error from the init could be useful as well
So when I have “lib_archive = false”, compilation appears to succeed (it says so in the terminal), but no serial outputs come through as you would expect with the code having monitoring enabled, e.g., no motor init, no pole pair checks, no current sense checks, etc. It just sits there not initializing.
I’m not too familiar with the capabilities of PlatformIO, so if there’s other information I can get that would be helpful, I’d appreciate any pointers!
@deffie I thought the recommendation was to use the same PWM timer for the 3 PWM signals?
Update - I tried changing the PWM pins to PA8, PA9, and PA10 - this worked and now the whine is gone. Thank you all for the help!
