Hi everyone. I am experiencing something strange. I moved testing my ifx007i board to Nucleo 144 due to some issues I hit with the Mega, which I’ll describe later. The board is F767ZI. This is the setup:
Using Arduino IDE. The Nucleo board runs fine, I can output on any pin, I tried with simple code. Outputs both PWM, digital, input analog, nothing out of the ordinary.
However when I build the SimpleFOC, after loading the build, the board goes mute, absolutely no response on any pin. Just to make sure, I embedded a bit of debug code to output on a pin not used by the ifx007i board, no result. I tested with the oscilloscope on all pins in case I mis-directed pins, nothing. I tried calling the pins with the Arduino names instead of addressing directly, same nothing. I am rather stumped. If you have experienced something similar, please help. Can’t think of anything at that point. I must be doing something really stupid but can’t catch it.
Below is the code.
BLDCDriver3PWM driver = BLDCDriver3PWM(D9, D10, D11, D3, D5, D6);
//target variable
float target_velocity = 10;
//driver.pwm_frequency = 30000;
// limiting motor movements
motor.voltage_limit = 2; // [V]
motor.velocity_limit = 100; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
Serial.println("Set target velocity [rad/s]. Example: T10 will set the target to 10 [Rad/s], T-10 will run in reverse.");
pinMode(D0,OUTPUT); // debug code to test Nucleo 144 / F767ZI
digitalWrite(D0,HIGH); delay(1); // debug code to test Nucleo 144 / F767ZI
digitalWrite(D0,LOW); delay(1); // debug code to test Nucleo 144 / F767ZI
