Hello everyone.
How can I know if my board (STM32F446RE) is measuring the current correctly?
Is it normal for the current value displayed in simpleFOCstudio to oscillate so much?
Thank you very much for your help.
Hello everyone.
Hey @Francesc_Riera_Vidal ,
Could you share your code? Also, which driver/motor are you using?
The motor driver board is X-NUCLEO-IHM07M1.
The code
// BLDC motor & driver instance PA8, PA9, PA10, PC10, PC11, PC12
// BLDCMotor(int pp, (optional R, KV))
// - pp - pole pair number
// - R - phase resistance value - optional
// - KV - motor KV rating [rpm/V] - optional
BLDCMotor motor = BLDCMotor(7);//motor chino
// BLDCDriver3PWM( int phA, int phB, int phC, int enA, int enB, int enC )
// - phA, phB, phC - A,B,C phase pwm pins
// - enA, enB, enC - enable pin for each phase (optional)
BLDCDriver3PWM driver = BLDCDriver3PWM(PA8, PA9, PA10, PC10, PC11, PC12);
//LowsideCurrentSense(shunt_resistance, gain, adc_a, adc_b, adc_c)
LowsideCurrentSense current_sense = LowsideCurrentSense(0.33, 1.528, PA0, PC1,PC0);
// Example of AS5600 configuration
//instantiate commander
void onMotor(char* cmd){commander.motor(&motor, cmd);}
void setup()
// configure i2C
Wire.setClock(400000);
driver.voltage_power_supply = 15.5;
// link driver
motor.torque_controller = TorqueControlType::dc_current;
//motor.foc_modulation = FOCModulationType::SinePWM;
motor.PID_velocity.P = 0.05;
motor.PID_velocity.I = 1;
motor.voltage_limit = 12;
motor.LPF_velocity.Tf = 0.01;
// angle loop controller
motor.P_angle.P = 20;
// angle loop velocity limit
motor.velocity_limit = 30;
current_sense.init();
motor.target = 4;
commander.add(‘M’,onMotor,“motor”);
// motor monitoring
commander.run();
Please place the motor.init()
before the current_sense.init()
You can see some examples for the correct order for initialisation here:
