You may also require the library I modified for the purpose, or you will get a click once per revolution as there is a small inadequacy in the open loop code. Actually I will just paste the modified code here.
#include "BLDCMotor.h"
#include "./communication/SimpleFOCDebug.h"
// see https://www.youtube.com/watch?v=InzXA7mWBWE Slide 5
// each is 60 degrees with values for 3 phases of 1=positive -1=negative 0=high-z
int trap_120_map[6][3] = {
{_HIGH_IMPEDANCE,1,-1},
{-1,1,_HIGH_IMPEDANCE},
{-1,_HIGH_IMPEDANCE,1},
{_HIGH_IMPEDANCE,-1,1},
{1,-1,_HIGH_IMPEDANCE},
{1,_HIGH_IMPEDANCE,-1}
// see https://www.youtube.com/watch?v=InzXA7mWBWE Slide 8
// each is 30 degrees with values for 3 phases of 1=positive -1=negative 0=high-z
int trap_150_map[12][3] = {
{-1,1,-1},
{-1,1,1},
{-1,-1,1},
{1,-1,1},
{1,-1,-1},
{1,_HIGH_IMPEDANCE,-1},
{1,1,-1}
// BLDCMotor( int pp , float R)
// - pp - pole pair number
// - R - motor phase resistance
// - KV - motor kv rating (rmp/v)
// - L - motor phase inductance
BLDCMotor::BLDCMotor(int pp, float _R, float _KV, float _inductance)
: FOCMotor()
// save pole pairs number
pole_pairs = pp;
// save phase resistance number
phase_resistance = _R;
// save back emf constant KV = 1/KV
// 1/sqrt(2) - rms value
KV_rating = _KV*_SQRT2;
// save phase inductance
phase_inductance = _inductance;
// torque control type is voltage by default
torque_controller = TorqueControlType::voltage;
Link the driver which controls the motor
void BLDCMotor::linkDriver(BLDCDriver* _driver) {
driver = _driver;
// init hardware pins
void BLDCMotor::init() {
if (!driver || !driver->initialized) {
motor_status = FOCMotorStatus::motor_init_failed;
SIMPLEFOC_DEBUG("MOT: Init not possible, driver not initialized");
return;
motor_status = FOCMotorStatus::motor_initializing;
SIMPLEFOC_DEBUG("MOT: Init");
// sanity check for the voltage limit configuration
if(voltage_limit > driver->voltage_limit) voltage_limit = driver->voltage_limit;
// constrain voltage for sensor alignment
if(voltage_sensor_align > voltage_limit) voltage_sensor_align = voltage_limit;
// update the controller limits
if(current_sense){
// current control loop controls voltage
PID_current_q.limit = voltage_limit;
PID_current_d.limit = voltage_limit;
if(_isset(phase_resistance) || torque_controller != TorqueControlType::voltage){
// velocity control loop controls current
PID_velocity.limit = current_limit;
}else{
// velocity control loop controls the voltage
PID_velocity.limit = voltage_limit;
P_angle.limit = velocity_limit;
_delay(500);
// enable motor
SIMPLEFOC_DEBUG("MOT: Enable driver.");
enable();
_delay(500);
motor_status = FOCMotorStatus::motor_uncalibrated;
// disable motor driver
void BLDCMotor::disable()
// set zero to PWM
driver->setPwm(0, 0, 0);
// disable the driver
driver->disable();
// motor status update
enabled = 0;
// enable motor driver
void BLDCMotor::enable()
// enable the driver
driver->enable();
// set zero to PWM
enabled = 1;
FOC functions
// FOC initialization function
int BLDCMotor::initFOC( float zero_electric_offset, Direction _sensor_direction) {
int exit_flag = 1;
motor_status = FOCMotorStatus::motor_calibrating;
// align motor if necessary
// alignment necessary for encoders!
if(_isset(zero_electric_offset)){
// abosolute zero offset provided - no need to align
zero_electric_angle = zero_electric_offset;
// set the sensor direction - default CW
sensor_direction = _sensor_direction;
// sensor and motor alignment - can be skipped
// by setting motor.sensor_direction and motor.zero_electric_angle
_delay(500);
if(sensor){
exit_flag *= alignSensor();
// added the shaft_angle update
sensor->update();
shaft_angle = shaftAngle();
}else {
exit_flag = 0; // no FOC without sensor
SIMPLEFOC_DEBUG("MOT: No sensor.");
// aligning the current sensor - can be skipped
// checks if driver phases are the same as current sense phases
// and checks the direction of measuremnt.
_delay(500);
if(exit_flag){
if(current_sense){
if (!current_sense->initialized) {
motor_status = FOCMotorStatus::motor_calib_failed;
SIMPLEFOC_DEBUG("MOT: Init FOC error, current sense not initialized");
exit_flag = 0;
}else{
exit_flag *= alignCurrentSense();
else SIMPLEFOC_DEBUG("MOT: No current sense.");
if(exit_flag){
SIMPLEFOC_DEBUG("MOT: Ready.");
motor_status = FOCMotorStatus::motor_ready;
}else{
SIMPLEFOC_DEBUG("MOT: Init FOC failed.");
disable();
return exit_flag;
// Calibarthe the motor and current sense phases
int BLDCMotor::alignCurrentSense() {
int exit_flag = 1; // success
SIMPLEFOC_DEBUG("MOT: Align current sense.");
// align current sense and the driver
exit_flag = current_sense->driverAlign(voltage_sensor_align);
if(!exit_flag){
// error in current sense - phase either not measured or bad connection
SIMPLEFOC_DEBUG("MOT: Align error!");
exit_flag = 0;
}else{
// output the alignment status flag
SIMPLEFOC_DEBUG("MOT: Success: ", exit_flag);
return exit_flag > 0;
// Encoder alignment to electrical 0 angle
int BLDCMotor::alignSensor() {
int exit_flag = 1; //success
SIMPLEFOC_DEBUG("MOT: Align sensor.");
// check if sensor needs zero search
if(sensor->needsSearch()) exit_flag = absoluteZeroSearch();
// stop init if not found index
if(!exit_flag) return exit_flag;
// if unknown natural direction
if(!_isset(sensor_direction)){
// find natural direction
// move one electrical revolution forward
for (int i = 0; i <=500; i++ ) {
float angle = _3PI_2 + _2PI * i / 500.0f;
setPhaseVoltage(voltage_sensor_align, 0, angle);
sensor->update();
_delay(2);
// take and angle in the middle
sensor->update();
float mid_angle = sensor->getAngle();
// move one electrical revolution backwards
for (int i = 500; i >=0; i-- ) {
float angle = _3PI_2 + _2PI * i / 500.0f ;
sensor->update();
_delay(2);
sensor->update();
float end_angle = sensor->getAngle();
setPhaseVoltage(0, 0, 0);
_delay(200);
// determine the direction the sensor moved
float moved = fabs(mid_angle - end_angle);
if (moved<MIN_ANGLE_DETECT_MOVEMENT) { // minimum angle to detect movement
SIMPLEFOC_DEBUG("MOT: Failed to notice movement");
return 0; // failed calibration
} else if (mid_angle < end_angle) {
SIMPLEFOC_DEBUG("MOT: sensor_direction==CCW");
sensor_direction = Direction::CCW;
} else{
SIMPLEFOC_DEBUG("MOT: sensor_direction==CW");
sensor_direction = Direction::CW;
// check pole pair number
if( fabs(moved*pole_pairs - _2PI) > 0.5f ) { // 0.5f is arbitrary number it can be lower or higher!
SIMPLEFOC_DEBUG("MOT: PP check: fail - estimated pp: ", _2PI/moved);
} else
SIMPLEFOC_DEBUG("MOT: PP check: OK!");
} else SIMPLEFOC_DEBUG("MOT: Skip dir calib.");
// zero electric angle not known
if(!_isset(zero_electric_angle)){
// align the electrical phases of the motor and sensor
// set angle -90(270 = 3PI/2) degrees
setPhaseVoltage(voltage_sensor_align, 0, _3PI_2);
_delay(700);
// read the sensor
sensor->update();
// get the current zero electric angle
zero_electric_angle = 0;
zero_electric_angle = electricalAngle();
//zero_electric_angle = _normalizeAngle(_electricalAngle(sensor_direction*sensor->getAngle(), pole_pairs));
_delay(20);
if(monitor_port){
SIMPLEFOC_DEBUG("MOT: Zero elec. angle: ", zero_electric_angle);
// stop everything
_delay(200);
}else SIMPLEFOC_DEBUG("MOT: Skip offset calib.");
return exit_flag;
// Encoder alignment the absolute zero angle
// - to the index
int BLDCMotor::absoluteZeroSearch() {
// sensor precision: this is all ok, as the search happens near the 0-angle, where the precision
// of float is sufficient.
SIMPLEFOC_DEBUG("MOT: Index search...");
// search the absolute zero with small velocity
float limit_vel = velocity_limit;
float limit_volt = voltage_limit;
velocity_limit = velocity_index_search;
voltage_limit = voltage_sensor_align;
shaft_angle = 0;
while(sensor->needsSearch() && shaft_angle < _2PI){
angleOpenloop(1.5f*_2PI);
// call important for some sensors not to loose count
// not needed for the search
sensor->update();
// disable motor
// reinit the limits
velocity_limit = limit_vel;
voltage_limit = limit_volt;
// check if the zero found
if(monitor_port){
if(sensor->needsSearch()) SIMPLEFOC_DEBUG("MOT: Error: Not found!");
else SIMPLEFOC_DEBUG("MOT: Success!");
return !sensor->needsSearch();
// Iterative function looping FOC algorithm, setting Uq on the Motor
// The faster it can be run the better
void BLDCMotor::loopFOC() {
// update sensor - do this even in open-loop mode, as user may be switching between modes and we could lose track
// of full rotations otherwise.
if (sensor) sensor->update();
// if open-loop do nothing
if( controller==MotionControlType::angle_openloop || controller==MotionControlType::velocity_openloop ) return;
// if disabled do nothing
if(!enabled) return;
// Needs the update() to be called first
// This function will not have numerical issues because it uses Sensor::getMechanicalAngle()
// which is in range 0-2PI
electrical_angle = electricalAngle();
switch (torque_controller) {
case TorqueControlType::voltage:
// no need to do anything really
break;
case TorqueControlType::dc_current:
if(!current_sense) return;
// read overall current magnitude
current.q = current_sense->getDCCurrent(electrical_angle);
// filter the value values
current.q = LPF_current_q(current.q);
// calculate the phase voltage
voltage.q = PID_current_q(current_sp - current.q);
// d voltage - lag compensation
if(_isset(phase_inductance)) voltage.d = _constrain( -current_sp*shaft_velocity*pole_pairs*phase_inductance, -voltage_limit, voltage_limit);
else voltage.d = 0;
break;
case TorqueControlType::foc_current:
// read dq currents
current = current_sense->getFOCCurrents(electrical_angle);
// filter values
current.d = LPF_current_d(current.d);
// calculate the phase voltages
voltage.d = PID_current_d(-current.d);
// d voltage - lag compensation - TODO verify
// if(_isset(phase_inductance)) voltage.d = _constrain( voltage.d - current_sp*shaft_velocity*pole_pairs*phase_inductance, -voltage_limit, voltage_limit);
break;
default:
// no torque control selected
SIMPLEFOC_DEBUG("MOT: no torque control selected!");
break;
// set the phase voltage - FOC heart function :)
setPhaseVoltage(voltage.q, voltage.d, electrical_angle);
// Iterative function running outer loop of the FOC algorithm
// Behavior of this function is determined by the motor.controller variable
// It runs either angle, velocity or torque loop
// - needs to be called iteratively it is asynchronous function
// - if target is not set it uses motor.target value
void BLDCMotor::move(float new_target) {
// downsampling (optional)
if(motion_cnt++ < motion_downsample) return;
motion_cnt = 0;
// shaft angle/velocity need the update() to be called first
// get shaft angle
// TODO sensor precision: the shaft_angle actually stores the complete position, including full rotations, as a float
// For this reason it is NOT precise when the angles become large.
// Additionally, the way LPF works on angle is a precision issue, and the angle-LPF is a problem
// when switching to a 2-component representation.
if( controller!=MotionControlType::angle_openloop && controller!=MotionControlType::velocity_openloop )
shaft_angle = shaftAngle(); // read value even if motor is disabled to keep the monitoring updated but not in openloop mode
// get angular velocity TODO the velocity reading probably also shouldn't happen in open loop modes?
shaft_velocity = shaftVelocity(); // read value even if motor is disabled to keep the monitoring updated
// set internal target variable
if(_isset(new_target)) target = new_target;
// calculate the back-emf voltage if KV_rating available U_bemf = vel*(1/KV)
if (_isset(KV_rating)) voltage_bemf = shaft_velocity/KV_rating/_RPM_TO_RADS;
// estimate the motor current if phase reistance available and current_sense not available
if(!current_sense && _isset(phase_resistance)) current.q = (voltage.q - voltage_bemf)/phase_resistance;
// upgrade the current based voltage limit
switch (controller) {
case MotionControlType::torque:
if(torque_controller == TorqueControlType::voltage){ // if voltage torque control
if(!_isset(phase_resistance)) voltage.q = target;
else voltage.q = target*phase_resistance + voltage_bemf;
voltage.q = _constrain(voltage.q, -voltage_limit, voltage_limit);
// set d-component (lag compensation if known inductance)
if(!_isset(phase_inductance)) voltage.d = 0;
else voltage.d = _constrain( -target*shaft_velocity*pole_pairs*phase_inductance, -voltage_limit, voltage_limit);
}else{
current_sp = target; // if current/foc_current torque control
break;
case MotionControlType::angle:
// TODO sensor precision: this calculation is not numerically precise. The target value cannot express precise positions when
// the angles are large. This results in not being able to command small changes at high position values.
// to solve this, the delta-angle has to be calculated in a numerically precise way.
// angle set point
shaft_angle_sp = target;
// calculate velocity set point
shaft_velocity_sp = P_angle( shaft_angle_sp - shaft_angle );
// calculate the torque command - sensor precision: this calculation is ok, but based on bad value from previous calculation
current_sp = PID_velocity(shaft_velocity_sp - shaft_velocity); // if voltage torque control
// if torque controlled through voltage
// use voltage if phase-resistance not provided
if(!_isset(phase_resistance)) voltage.q = current_sp;
else voltage.q = _constrain( current_sp*phase_resistance + voltage_bemf , -voltage_limit, voltage_limit);
else voltage.d = _constrain( -current_sp*shaft_velocity*pole_pairs*phase_inductance, -voltage_limit, voltage_limit);
break;
case MotionControlType::velocity:
// velocity set point - sensor precision: this calculation is numerically precise.
shaft_velocity_sp = target;
current_sp = PID_velocity(shaft_velocity_sp - shaft_velocity); // if current/foc_current torque control
// if torque controlled through voltage control
break;
case MotionControlType::velocity_openloop:
// velocity control in open loop - sensor precision: this calculation is numerically precise.
voltage.q = velocityOpenloop(shaft_velocity_sp); // returns the voltage that is set to the motor
voltage.d = 0;
break;
case MotionControlType::angle_openloop:
// angle control in open loop -
// TODO sensor precision: this calculation NOT numerically precise, and subject
// to the same problems in small set-point changes at high angles
// as the closed loop version.
voltage.q = angleOpenloop(shaft_angle_sp); // returns the voltage that is set to the motor
voltage.d = 0;
break;
// Method using FOC to set Uq and Ud to the motor at the optimal angle
// Function implementing Space Vector PWM and Sine PWM algorithms
// Function using sine approximation
// regular sin + cos ~300us (no memory usage)
// approx _sin + _cos ~110us (400Byte ~ 20% of memory)
void BLDCMotor::setPhaseVoltage(float Uq, float Ud, float angle_el) {
float center;
int sector;
float _ca,_sa;
switch (foc_modulation)
case FOCModulationType::Trapezoid_120 :
// determine the sector
sector = 6 * (_normalizeAngle(angle_el + _PI_6 ) / _2PI); // adding PI/6 to align with other modes
// centering the voltages around either
// modulation_centered == true > driver.voltage_limit/2
// modulation_centered == false > or Adaptable centering, all phases drawn to 0 when Uq=0
center = modulation_centered ? (driver->voltage_limit)/2 : Uq;
if(trap_120_map[sector][0] == _HIGH_IMPEDANCE){
Ua= center;
Ub = trap_120_map[sector][1] * Uq + center;
Uc = trap_120_map[sector][2] * Uq + center;
driver->setPhaseState(PhaseState::PHASE_OFF, PhaseState::PHASE_ON, PhaseState::PHASE_ON); // disable phase if possible
}else if(trap_120_map[sector][1] == _HIGH_IMPEDANCE){
Ua = trap_120_map[sector][0] * Uq + center;
Ub = center;
driver->setPhaseState(PhaseState::PHASE_ON, PhaseState::PHASE_OFF, PhaseState::PHASE_ON);// disable phase if possible
}else{
Uc = center;
driver->setPhaseState(PhaseState::PHASE_ON, PhaseState::PHASE_ON, PhaseState::PHASE_OFF);// disable phase if possible
break;
case FOCModulationType::Trapezoid_150 :
sector = 12 * (_normalizeAngle(angle_el + _PI_6 ) / _2PI); // adding PI/6 to align with other modes
if(trap_150_map[sector][0] == _HIGH_IMPEDANCE){
Ua= center;
Ub = trap_150_map[sector][1] * Uq + center;
Uc = trap_150_map[sector][2] * Uq + center;
}else if(trap_150_map[sector][1] == _HIGH_IMPEDANCE){
Ua = trap_150_map[sector][0] * Uq + center;
Ub = center;
driver->setPhaseState(PhaseState::PHASE_ON, PhaseState::PHASE_OFF, PhaseState::PHASE_ON); // disable phase if possible
}else if(trap_150_map[sector][2] == _HIGH_IMPEDANCE){
Uc = center;
driver->setPhaseState(PhaseState::PHASE_ON, PhaseState::PHASE_ON, PhaseState::PHASE_OFF); // disable phase if possible
}else{
driver->setPhaseState(PhaseState::PHASE_ON, PhaseState::PHASE_ON, PhaseState::PHASE_ON); // enable all phases
break;
case FOCModulationType::SinePWM :
// Sinusoidal PWM modulation
// Inverse Park + Clarke transformation
// angle normalization in between 0 and 2pi
// only necessary if using _sin and _cos - approximation functions
angle_el = _normalizeAngle(angle_el);
_ca = _cos(angle_el);
_sa = _sin(angle_el);
// Inverse park transform
Ualpha = _ca * Ud - _sa * Uq; // -sin(angle) * Uq;
Ubeta = _sa * Ud + _ca * Uq; // cos(angle) * Uq;
// center = modulation_centered ? (driver->voltage_limit)/2 : Uq;
center = driver->voltage_limit/2;
// Clarke transform
Ua = Ualpha + center;
Ub = -0.5f * Ualpha + _SQRT3_2 * Ubeta + center;
Uc = -0.5f * Ualpha - _SQRT3_2 * Ubeta + center;
if (!modulation_centered) {
float Umin = min(Ua, min(Ub, Uc));
Ua -= Umin;
Ub -= Umin;
Uc -= Umin;
break;
case FOCModulationType::SpaceVectorPWM :
// Nice video explaining the SpaceVectorModulation (SVPWM) algorithm
// https://www.youtube.com/watch?v=QMSWUMEAejg
// the algorithm goes
// 1) Ualpha, Ubeta
// 2) Uout = sqrt(Ualpha^2 + Ubeta^2)
// 3) angle_el = atan2(Ubeta, Ualpha)
// equivalent to 2) because the magnitude does not change is:
// Uout = sqrt(Ud^2 + Uq^2)
// equivalent to 3) is
// angle_el = angle_el + atan2(Uq,Ud)
float Uout;
// a bit of optitmisation
if(Ud){ // only if Ud and Uq set
// _sqrt is an approx of sqrt (3-4% error)
Uout = _sqrt(Ud*Ud + Uq*Uq) / driver->voltage_limit;
// angle normalisation in between 0 and 2pi
angle_el = _normalizeAngle(angle_el + atan2(Uq, Ud));
}else{// only Uq available - no need for atan2 and sqrt
Uout = Uq / driver->voltage_limit;
angle_el = _normalizeAngle(angle_el + _PI_2);
// find the sector we are in currently
sector = floor(angle_el / _PI_3) + 1;
// calculate the duty cycles
float T1 = _SQRT3*_sin(sector*_PI_3 - angle_el) * Uout;
float T2 = _SQRT3*_sin(angle_el - (sector-1.0f)*_PI_3) * Uout;
// two versions possible
float T0 = 0; // pulled to 0 - better for low power supply voltage
if (modulation_centered) {
T0 = 1 - T1 - T2; // modulation_centered around driver->voltage_limit/2
// calculate the duty cycles(times)
float Ta,Tb,Tc;
switch(sector){
case 1:
Ta = T1 + T2 + T0/2;
Tb = T2 + T0/2;
Tc = T0/2;
break;
case 2:
Ta = T1 + T0/2;
Tb = T1 + T2 + T0/2;
Tc = T0/2;
break;
case 3:
Ta = T0/2;
Tc = T2 + T0/2;
break;
case 4:
Ta = T0/2;
Tb = T1+ T0/2;
Tc = T1 + T2 + T0/2;
break;
case 5:
Ta = T2 + T0/2;
Tb = T0/2;
break;
case 6:
Tb = T0/2;
Tc = T1 + T0/2;
break;
default:
// possible error state
Ta = 0;
Tb = 0;
Tc = 0;
// calculate the phase voltages and center
Ua = Ta*driver->voltage_limit;
Ub = Tb*driver->voltage_limit;
Uc = Tc*driver->voltage_limit;
break;
// set the voltages in driver
driver->setPwm(Ua, Ub, Uc);
// Function (iterative) generating open loop movement for target velocity
// - target_velocity - rad/s
// it uses voltage_limit variable
float BLDCMotor::velocityOpenloop(float target_velocity){
// get current timestamp
static float other_shaft_angle = 0;// there is a mysterious flake out that occurs once per rotation, using a local variable helps a bit.
unsigned long now_us = _micros();
float delta_angle = 0;
// calculate the sample time from last call
//float Ts = (now_us - open_loop_timestamp) * 1e-6f;
unsigned long micros_int_dt = now_us-open_loop_timestamp;
// quick fix for strange cases (micros overflow + timestamp not defined)
if(micros_int_dt <= 0 || micros_int_dt > 1000) {
micros_int_dt = 1000;
delta_angle = (target_velocity*float(now_us-open_loop_timestamp))/1000000;
// calculate the necessary angle to achieve target velocity
other_shaft_angle = fmod((other_shaft_angle + delta_angle), _2PI);
shaft_angle = other_shaft_angle;
// for display purposes
shaft_velocity = target_velocity;
// use voltage limit or current limit
float Uq = voltage_limit;
if(_isset(phase_resistance)){
Uq = _constrain(current_limit*phase_resistance + fabs(voltage_bemf),-voltage_limit, voltage_limit);
// recalculate the current
current.q = (Uq - fabs(voltage_bemf))/phase_resistance;
// set the maximal allowed voltage (voltage_limit) with the necessary angle
setPhaseVoltage(Uq, 0, _electricalAngle(other_shaft_angle, pole_pairs));
// save timestamp for next call
open_loop_timestamp = now_us;
return Uq;
// Function (iterative) generating open loop movement towards the target angle
// - target_angle - rad
// it uses voltage_limit and velocity_limit variables
float BLDCMotor::angleOpenloop(float target_angle){
if(Ts <= 0 || Ts > 0.5f) Ts = 1e-3f;
// calculate the necessary angle to move from current position towards target angle
// with maximal velocity (velocity_limit)
// TODO sensor precision: this calculation is not numerically precise. The angle can grow to the point
// where small position changes are no longer captured by the precision of floats
// when the total position is large.
if(abs( target_angle - shaft_angle ) > abs(velocity_limit*Ts)){
shaft_angle += _sign(target_angle - shaft_angle) * abs( velocity_limit )*Ts;
shaft_velocity = velocity_limit;
}else{
shaft_angle = target_angle;
shaft_velocity = 0;
// sensor precision: this calculation is OK due to the normalisation
setPhaseVoltage(Uq, 0, _electricalAngle(_normalizeAngle(shaft_angle), pole_pairs));
return Uq;
Replace the contents of the BLDCmotor.cpp with that and you should be good.
oh, obviously you need to change the pins for the pwm and stuff. This works with the lepton v2.0 so you could just roll with that, it also works with the B-G431-ESC1, with different pins.
To reverse direction, simply specify a negative velocity. You just type commands into the serial monitor on arduino, or you can send them with another MCU easily. So T2 will set the speed to 2 radians per second. T2.5 etc. You can go way down to T0.01 radians or even zero.
I have no clue about your boards or wiring, but hopefully it is adequately documented.
Oh, don’t forget to set the voltages etc. in that code above, it will be different for you.
Oh, btw donations are very much welcome, please give to the project.
