im using the examples of simpleFOC library, currently, trying to estimate the number ofpoles i have so im using the AMT103 sensor and the find pole pairs example:
- Utility arduino sketch which finds pole pair number of the motor
- To run it just set the correct pin numbers for the BLDC driver and encoder A and B channel as well as the encoder PPR value.
- The program will rotate your motor a specific amount and check how much it moved, and by doing a simple calculation calculate your pole pair number.
- The pole pair number will be outputted to the serial terminal.
- If the pole pair number is well estimated your motor will start to spin in voltage mode with 2V target.
- If the code calculates negative pole pair number please invert your encoder A and B channel pins or motor connector.
- Try running this code several times to avoid statistical errors.
But in general if your motor spins, you have a good pole pairs number.
// BLDC motor instance
// its important to put pole pairs number as 1!!!
// Stepper motor instance
//StepperMotor motor = StepperMotor(1);
// Encoder(int encA, int encB , int cpr, int index)
Encoder encoder = Encoder(2, 3, 2048);
// interrupt routine intialisation
encoder.init();
// hardware interrupt enable
motor.linkSensor(&encoder);
// power supply voltage
// default 12V
// monitoring port
// pole pairs calculation routine
Serial.println(“Pole pairs (PP) estimator”);
Serial.println("-\n");
float pp_search_voltage = 4; // maximum power_supply_voltage/2
float pp_search_angle = 6*_PI; // search electrical angle to turn
// move motor to the electrical angle 0
motor.voltage_limit=pp_search_voltage;
motor.move(0);
// read the encoder angle
encoder.update();
float angle_begin = encoder.getAngle();
_delay(50);
// move the motor slowly to the electrical angle pp_search_angle
float motor_angle = 0;
while(motor_angle <= pp_search_angle){
motor_angle += 0.01f;
motor.move(motor_angle);
_delay(1);
// read the encoder value for 180
encoder.update();
float angle_end = encoder.getAngle();
_delay(50);
// turn off the motor
motor.move(0);
// calculate the pole pair number
int pp = round((pp_search_angle)/(angle_end-angle_begin));
Serial.print(F("Estimated PP : “));
Serial.println(pp);
Serial.println(F(“PP = Electrical angle / Encoder angle “));
Serial.print(pp_search_angle*180/_PI);
Serial.print(”/”);
Serial.print((angle_end-angle_begin)*180/_PI);
Serial.print(” = ");
Serial.println((pp_search_angle)/(angle_end-angle_begin));
Serial.println();
// a bit of monitoring the result
if(pp <= 0 ){
Serial.println(F(“PP number cannot be negative”));
Serial.println(F(" - Try changing the search_voltage value or motor/encoder configuration."));
return;
}else if(pp > 30){
Serial.println(F(“PP number very high, possible error.”));
}else{
Serial.println(F(“If PP is estimated well your motor should turn now!”));
Serial.println(F(" - If it is not moving try to relaunch the program!"));
Serial.println(F(" - You can also try to adjust the target voltage using serial terminal!"));
// set FOC loop to be used
// set the pole pair number to the motor
motor.pole_pairs = pp;
//align encoder and start FOC
Serial.println(F("\n Motor ready."));
Serial.println(F(“Set the target voltage using serial terminal:”));
// uq voltage
float target_voltage = 2;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_voltage);
// communicate with the user
serialReceiveUserCommand();
static String received_chars;
while (Serial.available()) {
// get the new byte:
received_chars += inChar;
// end of user input
if (inChar == ‘\n’) {
// change the motor target
target_voltage = received_chars.toFloat();
Serial.print("Target voltage: ");
Serial.println(target_voltage);
// reset the command buffer
received_chars = "";
