Hello everyone,
I’m using a BLDC motor and trying to control it with SimpleFOC and an Arduino uno in open-loop mode. Below, I’ll provide the motor’s datasheet and the code I used.
While running a test spin, I noticed white condensation forming inside the motor (since it’s made of plastic, it was clearly visible), and it heated up significantly. The power supplied was much lower than the rated power—I only wanted to check if the wiring was correct.
Now, I’m wondering:
- Is my motor damaged?
- Is there an issue with the code?
- Did I make a mistake with the power supply?
Please help me figure this out! Any advice would be greatly appreciated.
Thanks in advance!
// BLDCMotor( pp number , phase resistance, KV rating)
BLDCMotor motor = BLDCMotor(11 , 12.5, 100);
void doLimitCurrent(char* cmd) { command.scalar(&motor.current_limit, cmd); }
// limiting motor current (provided resistance)
motor.current_limit = 0.5; // [Amps]
// open loop control config
// init motor hardware
command.add('C', doLimitCurrent, "current limit");
Serial.begin(9600);
// using motor.current_limit and motor.velocity_limit
Datasheet
Adapter
