Hi everyone I tried to get value step by step in the simplefoc tuning video on YouTube and the problem with it is I can’t get the value of get.Angle() but I can get the value of getSensorAngle(); I didn’t what’s different between these two but it’s as I see the library is used a lot of getAngle() what do I miss in this condition. my motor is this link:motor it’s have 4 magnetic stator and on 6 rotor so pole pair should be 3 pp.
HallSensor sensor = HallSensor(3 ,2 ,4 ,3);
const int hallSensorPin1 = 2;
const int hallSensorPin2 = 3;
const int hallSensorPin3 = 4;
//const int8_t electric_sector[8] = { -1, 0, 4, 5, 2, 1, 3 , -1 };
//float getangle = ((electric_rotations * 6 + electric_sector) / cpr) * _2PI ;
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
float target = 0.0;
void serialLoop(){
static String received_chars;
while (Serial.available()){
char inChar = (char) Serial.read();
received_chars += inChar;
if (inChar =='\n'){
target = received_chars.toFloat();
Serial.print("Target = "); Serial.println(target);
received_chars = "";
sensor.pullup = Pullup::USE_EXTERN ;
// pinMode(2, INPUT_PULLUP);
// pinMode(3, INPUT_PULLUP);
// pinMode(4, INPUT_PULLUP);
sensor.enableInterrupts(doA,doB,doC);
delay(1000);
// int hallState1 = digitalRead(hallSensorPin1);
// int hallState2 = digitalRead(hallSensorPin2);
// int hallState3 = digitalRead(hallSensorPin3);
// String stateStr = String(hallState3) + String(hallState2) + String(hallState1);
// Serial.println(stateStr);
serialLoop();
Serial.print("\t");
Serial.print(sensor.getMechanicalAngle());
Serial.print("\t");
Serial.print(sensor.getSensorAngle());
Serial.print("\t");
// Serial.print();
