GM2804 + Arduino + simpleFOCShield cannot achieve 2000rpm
Hi All,
I am pretty new to BLDC motors. I have the aforementioned setup and the motor (https://ca.robotshop.com/products/ipower-gm2804-gimbal-motor-w-as5048a-encoder) should be able to spin ~2000rpm unloaded. I slowly step my velocity control up (with very conservative PI gains and slew) but cannot seem to get much higher than 1000rpm before the motor spontaneously changes direction and stops responding to velocity commands. Has anyone experienced this? This persists in open loop voltage control. I have checked and SPI speed and Arduino loop time should not be the cause.
This is the current Arduino sketch:
  • Velocity motion control example
  • Steps:
    1. Configure the motor and magnetic sensor
    1. Run the code
    1. Set the target velocity (in radians per second) from serial terminal
  • By using the serial terminal set the velocity value you want to motor to obtain
MagneticSensorSPI sensor = MagneticSensorSPI(9, 14, 0x3FFF);
// MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, 10);
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5, 8);
float target_velocity = 0;
// loopFOC frequency meter
unsigned long _lf_last_ms = 0;
uint32_t _lf_count = 0;
float _lf_hz = 0.0f;
// Set target velocity using RPM input
void doTargetRpm(char* cmd) {
float rpm = atof(cmd);
target_velocity = rpm * (2.0f * PI) / 60.0f; // store as rad/s
Serial.print(F("Target set (RPM): "));
Serial.println(rpm);
// Toggle between closed-loop velocity and open-loop velocity
void doToggleOpenLoop(char* cmd) {
(void)cmd;
if (motor.controller == MotionControlType::velocity_openloop) {
Serial.println(F(“Mode: closed-loop velocity”));
} else {
Serial.println(F(“Mode: open-loop velocity”));
// On-demand status print
void doPrintStatus(char* cmd) {
(void)cmd;
float rpm_meas = motor.shaft_velocity * 60.0f / (2.0f * PI);
float rpm_target = target_velocity * 60.0f / (2.0f * PI);
Serial.print(F("Target(RPM): “));
Serial.print(rpm_target);
Serial.print(F(” | RPM: “));
Serial.print(rpm_meas);
Serial.print(F(” | dir: “));
Serial.print(motor.sensor_direction == Direction::CW ? F(“CW”) : F(“CCW”));
Serial.print(F(” | mode: "));
Serial.println(motor.controller == MotionControlType::velocity_openloop ? F(“open-loop”) : F(“closed-loop”));
// Print PWM frequency
void doPrintPwmFreq(char* cmd) {
(void)cmd;
Serial.print(F("PWM frequency (Hz): "));
Serial.println(driver.pwm_frequency);
// Print loopFOC frequency
void doPrintLoopHz(char* cmd) {
(void)cmd;
Serial.print(F("loopFOC rate (Hz): "));
Serial.println(_lf_hz, 1);
// SimpleFOCDebug::enable(&Serial); // disable to improve loop rate
sensor.clock_speed = 8000000; // 8 MHz (AMS supports up to ~10 MHz)
driver.voltage_power_supply = 10;
driver.voltage_limit = 10;
driver.pwm_frequency = 50000;
// contoller configuration
motor.PID_velocity.P = 0.1f;
motor.PID_velocity.I = 0.05;
motor.voltage_limit = 10.0f;
motor.PID_velocity.output_ramp = 100;
// align sensor and start FOC
command.add(‘T’, doTargetRpm, “target velocity (RPM)”);
// add print command P (on-demand status)
command.add(‘P’, doPrintStatus, “print status”);
// add print PWM frequency command F
command.add(‘F’, doPrintPwmFreq, “print PWM frequency (Hz)”);
// add loop rate print command L
command.add(‘L’, doPrintLoopHz, “print loopFOC rate (Hz)”);
// toggle open-loop / closed-loop velocity control
command.add(‘O’, doToggleOpenLoop, “toggle open/closed loop velocity”);
Serial.println(F(“Set the target velocity using serial terminal:”));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// loopFOC rate counter
_lf_count++;
unsigned long _now = millis();
unsigned long _dt = _now - _lf_last_ms;
if (_dt >= 1000UL) {
_lf_hz = (float)_lf_count * 1000.0f / (float)_dt;
_lf_count = 0;
_lf_last_ms = _now;
// Status printing moved to on-demand command ‘P’
// motor.monitor();
And here is the output showing the flip and loss of control:
Target set (RPM): 500.00
Target(RPM): 500.00 | RPM: 405.70 | dir: CW | mode: closed-loop
Target(RPM): 500.00 | RPM: 470.62 | dir: CW | mode: closed-loop
Target(RPM): 500.00 | RPM: 486.32 | dir: CW | mode: closed-loop
Target set (RPM): 700.00
Target(RPM): 700.00 | RPM: 664.12 | dir: CW | mode: closed-loop
Target(RPM): 700.00 | RPM: 687.45 | dir: CW | mode: closed-loop
Target set (RPM): 900.00
Target(RPM): 900.00 | RPM: 865.12 | dir: CW | mode: closed-loop
Target(RPM): 900.00 | RPM: 873.54 | dir: CW | mode: closed-loop
Target(RPM): 900.00 | RPM: 897.31 | dir: CW | mode: closed-loop
Target set (RPM): 1000.00
Target(RPM): 1000.00 | RPM: 985.16 | dir: CW | mode: closed-loop
Target(RPM): 1000.00 | RPM: 998.06 | dir: CW | mode: closed-loop
Target set (RPM): 1100.00
Target(RPM): 1100.00 | RPM: -1255.24 | dir: CW | mode: closed-loop
Target(RPM): 1100.00 | RPM: -1263.39 | dir: CW | mode: closed-loop
Any help is much appreciated, thanks!
Lyndon
Changing direction sounds like probably the electrical angle is wrong. The auto-calibration usually only gets zero_electric_angle in the ballpark. Spin one way and then the other in MotionControlType::torque mode and adjust it until both directions are the same speed.
You could also try playing with motor.phase_inductance to reach higher speeds. It adds some d-axis voltage as speed increases to compensate for current phase lag, or will extend into field weakening if you set it higher than the motor’s actual inductance. Try 0.001 (one millihenry) to start.
