FOC Limited Speed reaching problem
This will use doubles because you don’t specify the constants as float.
Which means it won’t use the FPU as it handles only single precision (without f suffix and with f suffix)
This can slow down the code.
This is wrong, it should be 13.92f (24 * 0.58f) otherwise you do overmodulation.
motor.voltage_limit = 24;
I would also not use velocity control for now, only torque control.
FOC control would be faster, lag compensation will help if you cannot do FOC.
I also shared some of those tips here
