FOC Init Fails with iPower GM6208 (28 poles) + AMT103 Encoder + STM32 Nucleo F446RE
Hi everyone,
I’m currently facing an issue initializing FOC with the following setup:
:wrench: Hardware setup:
  • Motor: iPower GM6208-150T (Gimbal motor – 28 poles according to datasheet)
  • Encoder: AMT103 with A/B output (2048 PPR) microswitch set 0000 → 2048
  • Board: STM32 Nucleo F446RE
  • Driver: SimpleFOC Shield v3.2 (soldered for 3PWM: pins D6, D10, D5 with ENABLE on D8)
  • IDE: Arduino IDE 2.3.6 with STM32 board package (STM32F4 / Nucleo-64 F446RE)
:electric_plug: Encoder connections:
  • A = D3
  • B = D2
  • I = D4
:scroll: Code:
I’m using a slightly modified version of the angle_control.ino example. Key lines:
BLDCMotor motor = BLDCMotor(28);  // 28 pole pairs (based on datasheet)
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5, 8); // 3PWM + ENABLE
Encoder sensor = Encoder(3, 2, 2048, 4); // I’ve tested with and without index
On startup, the motor turns one full rotation (clockwise, from encoder side), but then I get the following output.
:receipt: Serial output with index enabled:
STM32-DRV: Restarting timer 4
STM32-DRV: Restarting timer 3
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Index search…
MOT: Error: Not found!
MOT: Init FOC failed.
Motor ready.
:receipt: Serial output without index (i.e. using only A/B):
Encoder sensor = Encoder(3, 2, 2048); // I’ve tested with and without index
MOT: sensor_direction==CW
MOT: PP check: fail - estimated pp: 14.81
MOT: Zero elec. angle: 4.26
MOT: No current sense.
MOT: Ready.
Motor ready.
In this case, the motor barely moves, and I’m unsure if the direction detection or pole pair estimation is accurate.
The sending of the T command does not seem coherent.
:red_question_mark: My questions:
  • Can the AMT103 encoder work reliably without the index pin in SimpleFOC?
  • Is the 28 pole pairs count too high for automatic pole detection? Should I skip that step
  • Should I manually set the encoder direction (sensor.direction = Direction::CW/CCW)?
  • Why does FOC fail with the index pin, but completes (even if poorly) without it?
  • Did I not fill in the pinouts correctly?
Full code :
 * Position/angle motion control example
 * Steps:
 * 1) Configure the motor and encoder
 * 2) Run the code
 * 3) Set the target angle (in radians) from serial terminal
 * NOTE :
 * > Arduino UNO example code for running velocity motion control using an encoder with index significantly
 * > Since Arduino UNO doesn't have enough interrupt pins we have to use software interrupt library PciManager.
 * > If running this code with Nucleo or Bluepill or any other board which has more than 2 interrupt pins
 * > you can supply doIndex directly to the encoder.enableInterrupts(doA,doB,doIndex) and avoid using PciManger
 * > If you don't want to use index pin initialize the encoder class without index pin number:
 * > For example:
 * > - Encoder encoder = Encoder(2, 3, 8192);
 * > and initialize interrupts like this:
 * > - encoder.enableInterrupts(doA,doB)
 * Check the docs.simplefoc.com for more info about the possible encoder configuration.
//BLDCMotor motor = BLDCMotor(11);
//BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8);
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5,8);
// encoder instance
//Encoder encoder = Encoder(2, 3, 8192);
//Encoder sensor = Encoder(2, 3, 2048);
Encoder sensor = Encoder(3, 2, 2048,4);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
// angle set point variable
float target_angle = 0;
  // aligning voltage [V]
  // contoller configuration
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 6;
  // angle P controller
  motor.P_angle.P = 20;
  motor.velocity_limit = 4;
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_angle);
  // motor.monitor();
1 Answer
1
It’s all good, I was able to solve my problem.
First, you need to set the number of pole pairs, not the total number of poles.
So I changed:
to :
Then, you need to add the interrupt for the index pin:
void doIndex() { sensor.handleIndex(); }
And modify the interrupt initialization from:
to:
sensor.enableInterrupts(doA, doB, doIndex);
Sorry for the late reply. I'm happy that you found your issue!
