Components:
Raspberry Pi Pico (Earle Philhower Arduino Core)
Motor drivers: SimpleFOC Mini v1.0
Sensors: AS5048A (SPI config)
- Bench power supply set to 12v
I have been trying to control 3 motors simultaneously but have only been successful with 2. As soon as I added a 3rd i started to get the “Failed to detect movement” error on the Motor 1. I can observe the motor moving during initialization, so this should indicate that the sensor is not working right? but when i print the sensor angle it updates properly. Also important to note that commenting out the code for the 3rd motor, effectively bringing me back to the 2 motor configuration I JUST tested and had working, yields the same error. I thought maybe i messed up the wiring while hooking up the 3rd but i have triple checked everything (it is kind of a nightmare though). If there are no obvious problems in my code I will disassemble the whole thing and reassemble to be absolutely sure.
Edit: I disassembled and reassembled the whole thing on a larger breadboard and organized everything much better. 1 by 1 I wired and tested each motor with the code, adding the next motor after confirming functionality. Again, I wired the 3rd motor and uncommented the code associated with its control and again MOTOR #1 got the aforementioned error despite clearly moving for alignment. Angles from sensor 1 accurately update upon manual rotation.
Here is the code:
#include <SPI.h>
// SPI pins
// Motor 1
#define CS1 17
#define IN1_1 10
#define IN2_1 11
#define IN3_1 12
#define EN_1 13
// Motor 2
#define CS2 20
#define IN1_2 3
#define IN2_2 4
#define IN3_2 5
#define EN_2 2
// Motor 3
#define CS3 21
#define IN1_3 22
#define IN2_3 26
#define IN3_3 27
#define EN_3 28
// create hardware objects
// MagneticSensorSPI(CS_pin, bit_resolution, angle_registry)
// Motor instance: 7 pole pairs, 14.65 ohm phase resistance, 135 KV
// Driver instance: (phA, phB, phC, EN)
// create hardware 1 objects
MagneticSensorSPI sensor1 = MagneticSensorSPI(CS1, 14, 0x3FFF);
BLDCMotor motor1 = BLDCMotor(7, 14.65, 135);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(IN1_1, IN2_1, IN3_1, EN_1);
// create hardware 2 objects
MagneticSensorSPI sensor2 = MagneticSensorSPI(CS2, 14, 0x3FFF);
BLDCMotor motor2 = BLDCMotor(7, 14.65, 135);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(IN1_2, IN2_2, IN3_2, EN_2);
// create hardware 3 objects
MagneticSensorSPI sensor3 = MagneticSensorSPI(CS3, 14, 0x3FFF);
BLDCMotor motor3 = BLDCMotor(7, 14.65, 135);
BLDCDriver3PWM driver3 = BLDCDriver3PWM(IN1_3, IN2_3, IN3_3, EN_3);
// monitor serial port
delay(3000);
// initialize and link sensor1
sensor1.init();
motor1.linkSensor(&sensor1);
// initialize and link driver1
driver1.voltage_power_supply = 12;
driver1.init();
motor1.linkDriver(&driver1);
//motor1.useMonitoring(Serial);
// set control loop type
motor1.torque_controller = TorqueControlType::voltage;
motor1.controller = MotionControlType::torque;
// initialize motor1
motor1.init();
motor1.initFOC();
delay(50);
// initialize and link sensor2
sensor2.init();
motor2.linkSensor(&sensor2);
// initialize and link driver 2
driver2.voltage_power_supply = 12;
driver2.init();
motor2.linkDriver(&driver2);
motor2.torque_controller = TorqueControlType::voltage;
motor2.controller = MotionControlType::torque;
// initialize motor2
motor2.init();
motor2.initFOC();
delay(50);
// initialize and link motor3
sensor3.init();
motor3.linkSensor(&sensor3);
// initialize and link driver3
driver3.voltage_power_supply = 12;
driver3.init();
motor3.linkDriver(&driver3);
motor3.torque_controller = TorqueControlType::voltage;
motor3.controller = MotionControlType::torque;
// initialize motor3
motor3.init();
motor3.initFOC();
delay(50);
float target_voltage = 3;
// // Sensor readings (comment out if not needed)
Serial.print("Sensor1 angle: ");
Serial.println(sensor1.getAngle());
Serial.print("\t");
Serial.print("Sensor2 angle: ");
Serial.print(sensor2.getAngle());
Serial.print("\t");
Serial.print("Sensor3 angle: ");
Serial.println(sensor3.getAngle());
// move motor1
motor1.loopFOC();
motor1.move(target_voltage);
// // move motor2
motor2.loopFOC();
motor2.move(target_voltage);
// // move motor2
motor3.loopFOC();
motor3.move(target_voltage);
I just don’t understand why I would get this error if the sensor is confirmed to be working and the motor is in fact moving on startup.
@Antun_Skuric Yeah this is my first time using SPI and I was banging my head against the wall for a while haha. Calling all 3 (sensor.init())’s at the start of setup is what I ended up doing; much cleaner that way.
– Cormac_McCarthyAh yeah, I just realized I did not read the post fully. :) I'm wondering if pulling the CS pins high is important though? Calling the init should be enough.
– Antun_Skuric
