For those interested in possible extensions to SimpleFOC, here is a function that uses several methods to compute the zero_electric_angle. I developed it as a learning tool, so there might be bugs.
#include <vector>
#include <sstream>
#include <string>
// Class to average a value and display it
class Avg {
private:
float _sum = 0;
float _min = MAXFLOAT;
float _max = -MAXFLOAT;
int _count = 0;
public:
void push(float value) {
_min = std::min(_min, value);
_max = std::max(_max, value);
_sum += value;
++_count;
void display(const char* name) {
const float avg = _sum / _count;
std::stringstream s;
s.precision(3);
s << "zero_electric_angle avg" << name << "=" << avg << " (min=" << _min
<< ", max=" << _max << ")";
SIMPLEFOC_DEBUG(s.str().c_str());
// Trapezoidal map from the SimpleFOC library
// Each step is 30 electrical degrees with values for 3 phases of 1, -1, 0
extern int trap_150_map[12][3];
// Compute zero_electric_angle with various methods
void testZeroAngles(BLDCMotor& m) {
// Number of angular steps we will use for each pole pair
static constexpr int STEP_COUNT_PER_PP = 12;
// Number of sensor readings we'll average for each step
static constexpr int SENSOR_AVG_COUNT = 100;
// Przpare an array to store results
std::vector<float> zeroElectricalAngles;
// Pre-compute the center phase voltage
const float center = m.modulation_centered ? (m.driver->voltage_limit) / 2
: m.voltage_sensor_align;
// Iterate over pole pairs and electrical steps. This performs a full
// mechanical revolution.
for (int pp = 0; pp < m.pole_pairs; ++pp) {
for (int elecStep = 0; elecStep < STEP_COUNT_PER_PP; ++elecStep) {
// Compute the electrical angle corresponding to this step
const float currentElectricalAngle =
elecStep * m.sensor_direction * _2PI / STEP_COUNT_PER_PP;
// Set the phases to the right value
m.driver->setPwm(
center + (float)trap_150_map[elecStep][0] * m.voltage_sensor_align,
center + (float)trap_150_map[elecStep][1] * m.voltage_sensor_align,
center + (float)trap_150_map[elecStep][2] * m.voltage_sensor_align);
_delay(700);
// Get the sensor value
float sensorAngleRad = 0;
for (int i = 0; i < SENSOR_AVG_COUNT; ++i) {
m.sensor->update();
sensorAngleRad += m.sensor->getMechanicalAngle();
sensorAngleRad /= SENSOR_AVG_COUNT;
// Compute the same value in electrical unit
float sensorAngleInElectricalUnit = _normalizeAngle(
(float)(m.sensor_direction * m.pole_pairs) * sensorAngleRad);
// Compute and store the zero electrical angle
const float zeroElectricalAngle = _normalizeAngle(
sensorAngleInElectricalUnit - currentElectricalAngle + _3PI_2);
zeroElectricalAngles.push_back(zeroElectricalAngle);
// Display something, so that we know it's alive
SIMPLEFOC_DEBUG("zero_electric_angle=", zeroElectricalAngle);
// Stop the motor
m.setPhaseVoltage(0, 0, 0);
// We'll display a lot of stuff
SIMPLEFOC_DEBUG("\n****** Test Zero Angle ******");
// Display the zero_electric_angle as computed by SimpleFOC
SIMPLEFOC_DEBUG("\n1. Zero electrical angle as computed by SimpleFOC");
SIMPLEFOC_DEBUG("zero_electric_angle = ", m.zero_electric_angle);
// Display the average 6 steps zero_electric_angle over a single electrical
// revolution
SIMPLEFOC_DEBUG(
"\n2. Zero electrical angle using 6 steps average (single electrical "
"revolution)");
Avg avg;
for (int i = 0; i < STEP_COUNT_PER_PP / 2; ++i) {
avg.push(zeroElectricalAngles[i * 2]);
avg.display("6");
// Display the average 6 intermediate steps zero_electric_angle over a single
// electrical revolution
SIMPLEFOC_DEBUG(
"\n3. Zero electrical angle using 6 intermediate steps average (single "
"electrical revolution)");
avg = Avg();
avg.push(zeroElectricalAngles[1 + i * 2]);
avg.display("6-i");
// Display the average 12 steps zero_electric_angle over a single electrical
// revolution
SIMPLEFOC_DEBUG(
"\n4. Zero electrical angle using 12 steps average (single electrical "
"revolution)");
avg = Avg();
for (int i = 0; i < STEP_COUNT_PER_PP; ++i) {
avg.push(zeroElectricalAngles[i]);
avg.display("12");
// Display the average 6 steps zero_electric_angle over a full mechanical
// revolution
SIMPLEFOC_DEBUG(
"\n5. Zero electrical angle using 6 steps average (full mechanical "
"revolution)");
avg = Avg();
for (int i = 0; i < zeroElectricalAngles.size() / 2; ++i) {
avg.display("6xPP");
// Display the average 12 steps zero_electric_angle over a full mechanical
// revolution
SIMPLEFOC_DEBUG(
"\n6. Zero electrical angle using 12 steps average (full mechanical "
"revolution)");
avg = Avg();
for (auto value : zeroElectricalAngles) {
avg.push(value);
avg.display("12xPP");
The testZeroAngles(motor) function should be used after SimpleFOC initialization in closed loop mode, for example at the end of your setup() function. It will make your motor rotate a full revolution, computing the zero_electric_angle for each of the [12 x pole_pairs] steps, then display some statistics.
Here is the output with my motor:
zero_electric_angle = 3.84
2. Zero electrical angle using 6 steps average (single electrical revolution)
zero_electric_angle avg6=3.66 (min=3.62, max=3.7)
3. Zero electrical angle using 6 intermediate steps average (single electrical revolution)
zero_electric_angle avg6-i=3.66 (min=3.61, max=3.73)
4. Zero electrical angle using 12 steps average (single electrical revolution)
zero_electric_angle avg12=3.66 (min=3.61, max=3.73)
5. Zero electrical angle using 6 steps average (full mechanical revolution)
zero_electric_angle avg6xPP=3.69 (min=3.57, max=3.82)
6. Zero electrical angle using 12 steps average (full mechanical revolution)
zero_electric_angle avg12xPP=3.68 (min=3.56, max=3.83)
Key takeways:
- It is imprecise to compute
zero_electric_angleon a single step as done by SimpleFOC, as values vary across steps (see for example the above output 2, where results vary from 3.62 to 3.7). - It is imprecise to compute
zero_electric_angleon a single electrical revolution as done by SimpleFOC, as values vary across pole pairs (see for example the above output 5, where results vary from 3.57 to 3.82). - Intermediate PI/12 steps looks a bit less precise that full PI/6 steps (see for example the min-max range difference between outputs 5 and 6). This confirms on my motor what @dekutree64 said here and here, although in a less dramatic way. If this is confirmed, then SimpleFOC shouldn’t use 3PI/2 as a single reference step, as 3PI/2 is an intermediate step.
Please let me know your thoughts.
