EVLSPIN32G4-ACT Hardware Support
I have a similiar design based on EVLSPIN32G4 it have STSPIN32G4 MCU. My hardware is almost identical with EVLSPIN32G4 board schematic. I just removed CANBUS support on hardware and changed MOSFET’s with some other brand.
I am having trouble to drive motors with my design but i am not sure if its simple foc or hardware related.
My main.cpp code on Platformio is like this:
#include "SimpleFOC.h"
#include "SimpleFOCDrivers.h"
#include "drivers/stspin32g4/STSPIN32G4.h"
#include "stm32g4xx_hal.h"
#include "HardwareSerial.h"
STSPIN32G4 driver = STSPIN32G4();
HallSensor sensor = HallSensor(PB6, PB7, PB8, 7); //THESE ARE MY HALL SENSOR PINS
LowsideCurrentSense currentSense = LowsideCurrentSense(0.0020, 10, PA2, PB1, _NC); //THESE ARE MCU INTERNAL OPAMP OUTPUTS, IF I USE PA6 INSTEAD OF PB1 IT GIVES THIS ERROR "STM32-CS: ERR: Analog pins dont belong to the same ADC!"
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
Commander commander = Commander(Serial1); //"NORMAL "Serial" DOESN'T WORK. "Serial1" WORKS WITH "-DSERIAL_UART_INSTANCE=1" ON PLATFORMIO.INI FILE.PA10 AND PA9 ARE SERIAL CONNECTION PINS
void onMotor(char* cmd){ commander.motor(&motor,cmd); }
Serial1.begin(115200);
motor.useMonitoring(Serial1);
pinMode(PC14, OUTPUT); //PC14 IS ONBOARD LED FOR JUST FOR VISUAL FEEDBACK IF MCU EXECUTES CODE.
digitalWrite(PC14, HIGH);
delay(1000);
driver.voltage_power_supply = 12; //I HAVE 12V PSU
driver.pwm_frequency = 32000;
currentSense.init();
Serial1.println(sensor.getVelocity());
commander.add('M',onMotor,"my motor motion");
void loop(){
motor.move(5);
My platformio.ini file as follows:
[env:genericSTM32G431CB]
platform = ststm32
board = genericSTM32G431VB
framework = arduino
lib_deps =
	askuric/Simple FOC@^2.3.4
	simplefoc/SimpleFOCDrivers@^1.0.8
    Wire
	SPI
board_build.ldscript = ./variant/ldscript.ld
monitor_speed = 115200
monitor_eol = LF
build_unflags = -Os
build_flags =
    -Ofast
	-DSIMPLEFOC_STM32_DEBUG
	-DPIO_FRAMEWORK_ARDUINO_ENABLE_CDC
    -DUSBD_USE_CDC
    -DUSBCON
    -DHAL_CORDIC_MODULE_ENABLED
    -DHAL_LPTIM_MODULE_ENABLED
Serial output of above code:
MOT: Monitor enabled!
TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: best: TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: Syncronising timers! Timer no. 1
STM32-DRV: Restarting timer 1
MOT: Init
MOT: Enable driver.
STM32-CS: Using ADC: 1
STM32-DRV: Stopping timer 1
0.00
MOT: Align sensor.
MOT: Init FOC failed.
My bench PSU is set to 12V and 3A limit, when i reset ESC it draws about 390mA for some time and doesn’t rotate motor.It halts on Init FOC failed. :expressionless:
Current sense thing was a bit complex so i tried it also on openloop with below code:
    driver.voltage_power_supply = 12.0f;
    motor.voltage_limit = driver.voltage_limit / 2.0f;
void loop(){
    motor.move(5.0f); // 5 rad/s open loop
    delayMicroseconds(100); // STM32G4 is very fast, add a delay in open loop if we do nothing else
In openloop configuration it draws about 138mA on PSU and doesn’t rotate also. Motor can be rotated with hands with soft ressistance, i can feel the pole points.
Another thing that i want to point that if i start a new project on platformio and upload same FOC code above serial output complains about this:
MOT: Init not possible, driver not initialized
ERR: Low-side cs not supported!
0.00
MOT: Align sensor.
ERR: Low-side cs not supported! i searched web and forum but i cannot find anything related with it.
If i clone this repo and use above FOC code this Low-side error thing doesn’t happen. But as i described above it draws about 390mA for some time and doesn’t rotate motor.
I am pretty confused and puzzled about this. In past i used B-G431B-ESC1 with Simple FOC which i expect this board behavior should be similiar.
Could someone point me right direction?
Thanks in advance.
Could you please post your schematics and perhaps some pictures?
Also, do you have an oscilloscope?
Thanks for reply. Sure thing!
Here is my schematic.
Here are some board photos:
I have 4 channel Rigol DS1054Z.Here some screenshots of output phases:(This screenshot belongs to velocity openloop)
What should i measure next? Are those waveforms on phases ok?
Many thanks.
Great, let me check the schematics, but they don’t seem OK, they are all on top of each other. Do they pulsate, does the duty change, like, they stretch and shrink, or they are stuck at that?
Can you measure the PWM from the MCU, one phase, low and high (2 signals) and the 3rd the phase from the 1/2 mosfets? Open velocity please.
I don’t see any obvious problems with the schematics, it appears very competent. Let’s see the waveforms from the three test points above. There might be an issue with the routing and the PCB, but that’s beyond my ability to debug over a text message, that needs hands-on with the gerbers and a microscope. Also, JLC is usually pretty good at what they do so that’s very unlikely that there is an SMD issue.
PS next time you make a dev board please expose those as test points. I see test points on the photo but can’t tell what’s what. If you haven’t, make test probes from jumper cables (I mean thin wires not car battery cables :slight_smile: ), shrinktubes and safety pins.
Do you have this in platformio.ini?
lib_archive = false
They don’t pulsate, duty doesn’t change they seem static. We can say they are stuck.
I will do this and report back but this week i will out of city.
It all assembled by me (without a stencil) with LCSC parts not from JLC so it may a SMD issue maybe :slightly_smiling_face: but i have unassembled PCB’s and components to make another board just i need free time to assemble them. In a nutshell i can make another board next week and post results.
I have some test points to test misc. stuff such as opamp outputs but not your pointed ones. Whitepawn noted.
lib_archive = false
No it wasn’t in platformio.ini but today i tested with “lib_archive = false” but same behavior
Thanks both of you for your replies.
But it’s clearly one of the problems.
Without it, simplefoc will pick the generic driver for pwm and current sense.
That’s why you had that message
So if he doesn’t assert
float _readADCVoltageLowSide(const int pinA, const void* cs_params)
then he will go with the default pwm and that could explain why it doesn’t “spin” ?
I mean this is a flag /side effect that the lib_archive is not really false.
That makes sense in my simplistic thinking. In other words he is not really driving with the dedicated
At least it explains the error message with current sense.
I am not sure how the STSPIN32G4 driver works.
I’m back.
Assembled two more boards just to be sure if i made any mistakes during assembly.
Triple checked schematics and parts (measured passive components before soldering) during assembly. I am pretty confident that %95 it is not an hardware issue.
I made measurements regarding 3 boards:
1 ST BOARD
Gates and U Phase Measurement:
High Side Gate From MCU (Measured Before R14)
Low Side Gate From MCU (Measured Before R15)
OUT1 U Phase to Motor (Measured from wire going to motor) (IGNORE 100V/Div it was x1, scope adjusted to x10 so read as 10V/Div)
2 ND BOARD
High Side Gate From MCU (Measured Before R14) (Yellow Channel 1)
Low Side Gate From MCU (Measured Before R15) (Cyan Channel 2)
OUT1 U Phase to Motor (Measured from wire going to motor) (Purple Channel 3)
Phase Measurements:
OUT1 U Phase to Motor (Measured from wire going to motor) (Yellow Channel 1)
OUT2 V Phase to Motor (Measured from wire going to motor) (Cyan Channel 2)
OUT3 W Phase to Motor (Measured from wire going to motor) (Purple Channel 3)
Same static behavior as before…
3 RD BOARD
Phase Measurements:
Same static behavior as above boards.
I used this openloop code (Modified only motor voltage limit, above scope shots belongs to this openloop code) :
    motor.voltage_limit = 1.0f; //ONLY THIS CHANGED
void loop(){
My platformio.ini file is this:
[env:genericSTM32G431VB]
platform = ststm32
framework = arduino
lib_archive = false
monitor_eol = LF
build_unflags = -Os
build_flags =
	-Ofast
	-DUSBD_USE_CDC
	-DUSBCON
lib_deps =
	adafruit/Adafruit NeoPixel@^1.11.0
        SPI
        Wire
As you can see i added lib_archive parameter and some others but result is the same that motor never spins. 3 different esc boards behave exactly same. They also drain about the same current during operation and idle blink program so i don’t think it is a hardware issue.
Any directions?
Thanks.
Could you share the serial output again, now with the lib_archive=false setting?
To verify that your driver is now initialized correctly?
Ok now i managed to partially worked it.
Started from scratch:
Downloaded funqi example and copied simple foc and simple foc driver dev branches to lib folder.
Platformio file is stock except “-DSERIAL_UART_INSTANCE=1” parameter:
platform = ststm32
framework = arduino
upload_protocol = stlink
lib_archive = false
monitor_eol = LF
build_unflags = -Os
build_flags =
    -Ofast
    -DUSBD_USE_CDC
    -DUSBCON
lib_deps =
Here is the code:
#include "utilities/stm32math/STM32G4CORDICTrigFunctions.h"
#include "settings/stm32/STM32FlashSettingsStorage.h"
HallSensor sensor = HallSensor(PB6, PB8, PB7, 15);
// interrupt routine initialization
STM32FlashSettingsStorage settings = STM32FlashSettingsStorage(); // use top page of flash for settings (2kB)
void onMotor(char* cmd) { commander.motor(&motor, cmd); }
void doSaveSettings(char *cmd) { settings.saveSettings(); }
void doLoadSettings(char *cmd) { settings.loadSettings(); }
void doCalibration(char *cmd) {
    motor.sensor_direction = Direction::UNKNOWN;
    motor.zero_electric_angle = 0.0f;
    Serial.println("Motor calibration...");
    Serial.println("Calibration found:");
    Serial.print("   Direction: Direction::");
    Serial.println((motor.sensor_direction==Direction::CW)?"CW":((motor.sensor_direction==Direction::CCW)?"CCW":"UNKNOWN"));
    Serial.print("  Zero Angle: ");
    Serial.println(motor.zero_electric_angle, 6);
void printDriverStatus();
uint32_t ts = 0;
    SimpleFOCDebug::enable();
    delay(5000);
    Serial1.println("Welcome to FunQi Driver Firmware");
    //motor.linkSensor(&sensor);
    Serial.println("Initializing CORDIC");
    if (!SimpleFOC_CORDIC_Config())
        Serial1.println("CORDIC init failed");
    Serial1.println("Initializing Driver");
    driver.voltage_limit = 10.0f;
    motor.voltage_sensor_align = 1.5;
    delay(1);
    Serial1.print("Driver ready: ");
    Serial1.println(driver.isReady()?"true":"false");
    Serial1.print("Driver fault: ");
    Serial1.println(driver.isFault()?"true":"false");
    //COMMENTS
    //Serial1.println("Unlocking driver...");
    //driver.unlock();
    //driver.lock();
    //STSPIN32G4PowMng powmng = driver.getPowMngRegister();
    //Serial.print("VCC voltage: ");
    //Serial.println(powmng.vcc_val);
    // Serial.println("Setting VCC to 10V");
    // powmng.vcc_val = 0b01;
    // driver.setPowMngRegister(powmng);
    Serial1.println("Locking driver...");
    driver.lock();
    driver.clearFaults();
    Serial1.println("Initializing Sensor");
    //sensor.checkcrc = true;
    // options1.uvw_off = 0b1;
    // sensor.setOptions1(options1);
    // sensor.setABZEnabled(true);
    // sensor.setABZResolution(16000-1); // sets 16000 PPR
    Serial1.println("Sensor initialized, start angle: ");
    Serial1.println(sensor.getAngle());
    Serial1.println("Initializing Motor");
    motor.motion_downsample = 4;
    Serial1.println("Initializing Settings");
    settings.addMotor(&motor);
    SimpleFOCRegister regs[] = SIMPLEFOC_SETTINGS_REGISTERS_MINIMAL;
    settings.setRegisters(regs, 2);
    settings.init();
    SettingsStatus loadStatus = settings.loadSettings();
    Serial1.println("Motor enabled");
    if (loadStatus == SFOC_SETTINGS_SUCCESS) {
        Serial1.println("Calibration loaded:");
        Serial1.print("   Direction: Direction::");
        Serial1.println((motor.sensor_direction==Direction::CW)?"CW":((motor.sensor_direction==Direction::CCW)?"CCW":"UNKNOWN"));
        Serial1.print("  Zero Angle: ");
        Serial1.println(motor.zero_electric_angle, 6);
    else
        Serial1.println("Motor calibration...");
    if (motor.motor_status == FOCMotorStatus::motor_ready && loadStatus != SFOC_SETTINGS_SUCCESS) {
        Serial1.println("Calibration found:");
        Serial1.println("Saving calibration...");
            Serial1.println("Save successful");
        else
            Serial1.println("Save failed");
    if (motor.motor_status == FOCMotorStatus::motor_ready)
        Serial1.println("Motor Ready");
    else
        Serial1.println("Motor NOT Ready");
    Serial1.println("Initializing comms");
    commander.add('M', onMotor, "Motor 1");
    commander.add('S', doSaveSettings, "Save settings");
    commander.add('L', doLoadSettings, "Load settings");
    commander.add('C', doCalibration, "Calibrate motor");
    Serial1.println("Setup complete");
    ts = millis();
    motor.target = 0.0f;
int count = 0;
int crcerrs = 0;
void loop(){
    uint32_t now = millis();
    if (now-ts>1000) {
        Serial1.print("It/s: ");
        Serial1.print(count);
        Serial1.print("  Fault: ");
        Serial1.print(driver.isFault()?"true":"false");
        Serial1.print("  Angle: ");
        Serial1.print(sensor.getAngle());
        Serial1.print("  Status: ");
        //Serial1.print(sensor.getStatus());
        Serial1.print("  CRC Errs: ");
        Serial1.println(crcerrs);
        count = 0;
        crcerrs = 0;
        ts = now;
    count++;
    commander.run();
void printDriverStatus() {
    Serial1.println("Driver status: ");
    STSPIN32G4Status status = driver.status();
    Serial1.print("      Lock: ");
    Serial1.println(status.lock?"LOCKED":"UNLOCKED");
    Serial1.print("  VCC UVLO: ");
    Serial1.println(status.vcc_uvlo?"YES":"NO");
    Serial1.print("     VDS P: ");
    Serial1.println(status.vds_p?"YES":"NO");
    Serial1.print("     RESET: ");
    Serial1.println(status.reset?"YES":"NO");
    Serial1.print("      TSHD: ");
    Serial1.println(status.thsd?"YES":"NO");
And here is the code serial output:
Initializing Driver
Driver ready: true
Driver fault: false
Driver status:
      Lock: LOCKED
  VCC UVLO: NO
     VDS P: NO
     RESET: NO
      TSHD: NO
Locking driver...
Driver status:
      Lock: LOCKED
  VCC UVLO: NO
     VDS P: NO
     RESET: NO
      TSHD: NO
Driver ready: true
Driver fault: false
Initializing Sensor
0.00
Initializing Motor
Motor enabled
Motor NOT Ready
Initializing comms
Setup complete
It/s: 371228  Fault: false  Angle: -0.07  Status:   CRC Errs: 0
It/s: 371040  Fault: false  Angle: -0.07  Status:   CRC Errs: 0
I tested with hoverboard motor and the problem is motor rotates forward and backward but it cannot detect movement of rotor from hall sensors. Here is a video of it.
Because of no movement detection from hall sensors motor cannot be initialized i believe.I checked hall sensors output with osciloscope it seems fine. Openloop still doesn’t work at all.
Any thoughts?
After countless tries with different parameters openloop is now working.
This is the openloop code that i used:
BLDCMotor motor = BLDCMotor(6);
void setup()
    SimpleFOCDebug::enable(&Serial1);
    driver.voltage_limit = 1.5f;
    motor.enable();
void loop()
    motor.move(20.0f); // 5 rad/s open loop
And here is the most important part platformio.ini file:
platform = ststm32
framework = arduino
lib_archive = false
build_flags =
	;-DPIO_FRAMEWORK_ARDUINO_ENABLE_CDC
   ; -DUSBD_USE_CDC
   ; -DUSBCON
    ;-DHAL_CORDIC_MODULE_ENABLED //THIS CAUSES MOTOR NOT TO SPIN BUT LOCK
    ;-DHAL_LPTIM_MODULE_ENABLED
    ;-D ARDUINO_GENERIC_G431VBTX //THIS CAUSES NOT ROTATE MOTORS CAL
    ;-DHAL_EXTI_MODULE_ENABLED
    ;-DHAL_RTC_MODULE_ENABLED
    ;-DHAL_GPIO_MODULE_ENABLED
    -D ARDUINO_GENERIC_G431CBUX //THIS IS THE MOST IMPORTANT BIT.WITH THIS OPENLOOP WORKS
lib_deps =
	;https://github.com/simplefoc/Arduino-FOC.git //I DIRECTLY CLONED GITS AND EXTRACTED FOLDERS TO LIB FOLDER OF VSCODE
	;https://github.com/simplefoc/Arduino-FOC-drivers.git#dev
With -D ARDUINO_GENERIC_G431CBUX parameter on platformio.ini openloop works without issue. So i am relaxed that my hardware design is just fine and works. :slightly_smiling_face: :partying_face:
If i enable cordic module motor behaves exactly described as before. It just locks itself i am not sure why.
The problem is now it cannot read hall sensor values. I tried to print them to serial output and rotate motor with my hand but angle and velocity values are always zero. I tested my hall sensor just to be sure if it works correctly with “B-G431B-ESC1” hall sensors works fine but with “EVLSPIN32G4” it doesn’t work.
Here is my sample code to test just hall sensors:
HallSensor sensor = HallSensor(PB6, PB7, PB8, 7); //THIS IS FOR EVLSPIN32G4
//HallSensor sensor = HallSensor(A_HALL1, A_HALL2, A_HALL3, 7); //THIS IS FOR B-G431B-ESC
uint32_t ts = 0;
    delay(5000);
    ts = millis();
int count = 0;
void loop(){
    if (now-ts>1000) {
        sensor.update();
        Serial1.print("  Velocity: ");
        count = 0;
        ts = now;
    count++;
Right now i don’t have hardware with me but in evening i can provide log outputs of above hall test code.
Do you also include the required initialisation code for the CORDIC in the setup()?
    SimpleFOC_CORDIC_Config();      // initialize the CORDIC
can anybudy help that how can we ran motor in arduino with stspin32g4 act board as it pwm gls and ghs pin not accepted by simple foc format nd i costumised board replace 0.02ohm registor with 0.003 ohm is find ?
Replacing the shunt resistors is no problem, but to run SimpleFOC on this board will require you write a custom firmware for it.
We have a driver for the STSPING4 chip, which will handle most of what you need, and you can look at this repository: simplefoc_funqi_example/src at main · runger1101001/simplefoc_funqi_example · GitHub for an example of using this driver with another board.
