Hello guys,
I’ve promised to myself to solve this issue…but no way! I really need your help. Here below my configuration:
- ESP32S3
- DRV8302 driver
- Motor with phase resistance 2Ohm
- Encoder: 500ppr
Here the schematics:
Here below the code:
// SE ABILITI SimpleFOC deve abilitarlo anche nel platformio.ini!!!!!!
// DRV8302 pins connections
#define INH_A 11
#define INH_B 10
#define INH_C 9
#define EN_GATE 8
#define M_PWM 2
#define M_OC 1
#define OC_ADJ 3
#define IOUTA 15
#define IOUTB 16
#define IOUTC 17
// motor instance
// driver instance
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
// DRV8302 board has 0.005Ohm shunt resistors and the gain of 12.22 V/V
LowsideCurrentSense cs = LowsideCurrentSense(0.005f, 12.22f, IOUTA, IOUTB, IOUTC);
// encoder instance
Encoder encoder = Encoder(4, 5, 500);
// channel A and B callbacks
// DRV8302 specific code
// M_OC - enable over-current protection
pinMode(M_OC,OUTPUT);
digitalWrite(M_OC,LOW);
// M_PWM - enable 3pwm mode
pinMode(M_PWM,OUTPUT);
digitalWrite(M_PWM,HIGH);
// OD_ADJ - set the maximum over-current limit possible
pinMode(OC_ADJ,OUTPUT);
digitalWrite(OC_ADJ,HIGH);
encoder.init();
motor.linkSensor(&encoder);
// link driver
cs.linkDriver(&driver);
// limiting motor movements
motor.phase_resistance = 2.0; // [Ohm]
motor.current_limit = 0.3; // [Amps] - if phase resistance defined
//motor.voltage_limit = 1; // [V] - if phase resistance not defined
motor.velocity_limit = 5; // [rad/s] cca 50rpm
// aligning voltage
//motor.torque_controller = TorqueControlType::voltage;
// velocity PID controller parameters
// default P=0.5 I = 10 D = 0
motor.PID_velocity.P = 0.025;
motor.PID_velocity.I = 0.2;
motor.PID_velocity.D = 0.0;
motor.LPF_velocity.Tf = 0.01;
// initialize current sense
cs.init();
motor.linkCurrentSense(&cs);
// driver 8302 has inverted gains on all channels
cs.gain_a *= -1;
cs.gain_b *= -1;
cs.gain_c *= -1;
cs.skip_align = true;
// align sensor and start FOC
// set the initial motor target
// motor.target = 0.2; // Amps - if phase resistance defined
motor.target = 1; // Volts
// command.add('T', doTarget, "target current"); // - if phase resistance defined
command.add('M',doMotor, "motor");
Serial.println(F("Set the target using serial terminal:"));
If I do not use the current sense, everything works perfectly (PID parameters tuned accordingly).
The problem arises when the cs.init() (current sense initialization) happens: the ESP32S3 is crashing with core dump, exactly if I uncomment this function. I’ve searched everywhere inside the community forum but I really have not found any solution on this…I’m struggling since 4 days now but no way…thank you!!!
