Hi everyone,
I am currently working on an esp32-s3 with Simplefoc shield v2.0.4. I am using AS5048A magnetic encoder and Cubemars GL40 motor. You can check the test evrimoment from the image.
You can also check the code that I am using
BLDCMotor motor = BLDCMotor(14, 2.25, 70);
BLDCDriver3PWM driver = BLDCDriver3PWM(15,16,17,7);
InlineCurrentSense currentSense = InlineCurrentSense(0.01, 50, 40, 41);
float target = 0;
void doTarget(char* cmd) { command.scalar(&target, cmd); }
void doCommand(char* cmd) { command.motor(&motor, cmd); }
void sensor_test(void)
sensor.update();
Serial.print("\t");
_delay(100);
// sensor
//driver
driver.voltage_power_supply = 16;
//current sense
currentSense.init();
//sensor index
//motion control
motor.motion_downsample = 0.0;
// PID
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 10;
motor.PID_velocity.output_ramp = 100.0;
motor.PID_velocity.limit = 0.3;
motor.LPF_velocity.Tf = 0.1;
motor.P_angle.P = 20.0;
motor.P_angle.I = 0.0;
motor.P_angle.D = 0.0;
motor.P_angle.output_ramp = 0.0;
motor.P_angle.limit = 1000.0;
motor.LPF_angle.Tf = 0.0;
// motor.PID_current_q.P = 3.0;
// motor.PID_current_q.I = 300.0;
// motor.PID_current_q.D = 0.0;
// motor.PID_current_q.output_ramp = 0.0;
// motor.PID_current_q.limit = 7.0;
// motor.LPF_current_q.Tf = 0.02;
// motor.PID_current_d.P = 3.0;
// motor.PID_current_d.I = 300.0;
// motor.PID_current_d.D = 0.0;
// motor.PID_current_d.output_ramp = 0.0;
// motor.PID_current_d.limit = 7.0;
// motor.LPF_current_d.Tf = 0.02;
motor.velocity_limit = 50.0;
motor.current_limit = 2.0;
//motor.modulation_centered = 1.0;
//monitor
motor.monitor_variables = _MON_VEL | _MON_TARGET | _MON_CURR_D | _MON_CURR_Q;
motor.monitor_downsample=500;
//motor
//commander
command.add('M', doCommand, "motor command");
Serial.println(F("Set the target using serial terminal:"));
#if 1
motor.move(target);
#else
sensor_test();
#endif
Here is the issue; I am trying to drive in a torque control mode. When I tried to debug from Simplefoc studio, Current Q and Current D do not respond to anyting. They remain 0 and do not give responds to any change I made. When I give target like 0.1A, driver gives full force up to 2.3A (I checked from Oscilloscope). Even I change target to 0, it remains like that and do not stop. Also there is a shaking issue on motor drive. You can check screenshots from the below.
as seen in the upper image, Current Q remain 0 and do not goes to target. Also there is a shaking issue that I mentioned can be seen in velocity graph.
I couldn’t solve the issue. Any idea to solve? I am glad to hear any advice. Thanks
