Hi, I am trying to use ESP32 Wroom 32 with TMC6300, with 6PWM driver.
> // Open loop motor control example
> #include <SimpleFOC.h>
> // BLDC motor & driver instance
> // BLDCMotor motor = BLDCMotor(pole pair number);
> BLDCMotor motor = BLDCMotor(11);
> // BLDCDriver3PWM driver = BLDCDriver3PWM(pwmA, pwmB, pwmC, Enable(optional));
> BLDCDriver6PWM driver = BLDCDriver6PWM(26,25,27,32,12,33);
> // Stepper motor & driver instance
> //StepperMotor motor = StepperMotor(50);
> //StepperDriver4PWM driver = StepperDriver4PWM(9, 5, 10, 6, 8);
> //target variable
> float target_velocity = 5;
> // instantiate the commander
> Commander command = Commander(Serial);
> void doTarget(char* cmd) { command.scalar(&target_velocity, cmd); }
> void doLimit(char* cmd) { command.scalar(&motor.voltage_limit, cmd); }
> void setup() {
> // driver config
> // power supply voltage [V]
> driver.voltage_power_supply = 5;
> // limit the maximal dc voltage the driver can set
> // as a protection measure for the low-resistance motors
> // this value is fixed on startup
> driver.voltage_limit = 3;
> driver.init();
> // link the motor and the driver
> motor.linkDriver(&driver);
> // limiting motor movements
> // limit the voltage to be set to the motor
> // start very low for high resistance motors
> // current = voltage / resistance, so try to be well under 1Amp
> motor.voltage_limit = 3; // [V]
> // open loop control config
> motor.controller = MotionControlType::velocity_openloop;
> // init motor hardware
> motor.init();
> // add target command T
> command.add('T', doTarget, "target velocity");
> command.add('L', doLimit, "voltage limit");
> Serial.begin(115200);
> Serial.println("Motor ready!");
> Serial.println("Set target velocity [rad/s]");
> _delay(1000);
> void loop() {
> // open loop velocity movement
> // using motor.voltage_limit and motor.velocity_limit
> motor.move(target_velocity);
> // user communication
> command.run();
Blockquote
I am trying to send 5rad/s but it is not taking the data to ESP.
