I’m developing a small robotic SCARA-type arm. Right now I can send commands to two iPower GM2804 motors with AS5048A magnetic encoders from a browser.
Here’s the code, which is basically the angle_control example:
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
// MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, 10);
MagneticSensorSPI sensor = MagneticSensorSPI(7, 14, 0x3FFF);
// MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 5, 4, 3);
// angle set point variable
float target_angle = 0;
// contoller configuration
motor.PID_velocity.P = 0.2f; //ORIGINALLY 0.2f -Svavar
motor.PID_velocity.I = 5; //ORIGINALLY 20 -Svavar
motor.PID_velocity.D = 0; //ORIGINALLY 0 -Svavar
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.01f; //ORIGINALLY 0.01f -Svavar
// angle P controller
motor.P_angle.P = 5; // this was originally 20 -Svavar
motor.velocity_limit = 10; // this was originally 20 -Svavar
// VERBOSE MONITORING OUTPUT
command.verbose = VerboseMode::machine_readable; // can be set using the webcontroller - optional
// align sensor and start FOC
// OUTPUT MONITORING DATA TO SIMPLEFOC STUDIO
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
I got this to work with after applying the fix for the Xiao SAMD21 suggested by @runger. I’m using Xiao SAMD21 modules with SimpleFOC Mini drivers. Now I’m designing my own board for the robot arm, and I’d like to use the bare SAMD21E18A chip instead of the Xiao module.
I have a SAMD21E18A on a basic board, not connected to a motor driver, just to see if I can get code onto it. I’ve managed to put a bootloader on it using EDBG and in the Arduino IDE I can get it to echo serial messages back to me. Nice!
I’m using a SAMD Arduino core that was made for the Fab Lab community. The core supports the SAMD21E18A chip, but I’m wondering if another core would work better with SimpleFOC, because I get an Error compiling for board Generic x21E
when trying to compile the angle_control example. I’ve tried it with and without the @runger fix for the Xiao SAMD21 module. It works better with the fix, but I still get the following errors:
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd21_mcu.cpp: In function 'EPioType getPeripheralOfPermutation(int, int)':
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd21_mcu.cpp:128:49: error: 'PIO_TIMER_ALT' was not declared in this scope
return ((permutation>>pin_position)&0x01)==0x1?PIO_TIMER_ALT:PIO_TIMER;
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd21_mcu.cpp:128:49: note: suggested alternative: 'PER_TIMER_ALT'
PER_TIMER_ALT
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd21_mcu.cpp:128:63: error: 'PIO_TIMER' was not declared in this scope
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd21_mcu.cpp:128:63: note: suggested alternative: 'PER_TIMER'
PER_TIMER
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp: In function 'tccConfiguration getTCCChannelNr(int, EPioType)':
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:82:64: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'EPortType {aka _EPortType}' [-fpermissive]
struct wo_association& association = getWOAssociation(pinDesc.ulPort, pinDesc.ulPin);
In file included from C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:4:0:
c:\users\...\documents\arduino\libraries\simple_foc\src\drivers\hardware_specific\samd\samd_mcu.h:110:24: note: initializing argument 1 of 'wo_association& getWOAssociation(EPortType, uint32_t)'
struct wo_association& getWOAssociation(EPortType port, uint32_t pin);
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:85:18: error: 'PIO_TIMER' was not declared in this scope
if (peripheral==PIO_TIMER) {
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:85:18: note: suggested alternative: 'PER_TIMER'
PER_TIMER
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:89:23: error: 'PIO_TIMER_ALT' was not declared in this scope
else if (peripheral==PIO_TIMER_ALT) {
C:\Users\...\Documents\Arduino\libraries\Simple_FOC\src\drivers\hardware_specific\samd\samd_mcu.cpp:89:23: note: suggested alternative: 'PER_TIMER_ALT'
PER_TIMER_ALT
Using library Simple_FOC at version 2.3.0 in folder: C:\Users\...\Documents\Arduino\libraries\Simple_FOC
Using library SPI at version 1.0 in folder: C:\Users\...\AppData\Local\Arduino15\packages\Fab_SAM_Arduino\hardware\samd\1.11.0\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\...\AppData\Local\Arduino15\packages\Fab_SAM_Arduino\hardware\samd\1.11.0\libraries\Wire
exit status 1
Error compiling for board Generic x21E.
