Easy controller 3 + SimpleFOC?
Would SimpleFOC run on this hardware? GitHub - pgrady3/EasyController3: A simple BLDC motor controller, and the evolution of the EasyController2
Don’t see why not…
It has 1-shunt low-side sensing, so that would not be supported, but otherwise it should be possible. It has Hall Sensor inputs, which might also work for an encoder. And I suppose with long headers you could access the SPI on the Pico, that might be worth checking. Then you could use SPI sensors too.
Nice, it uses a pico. It’s pretty expensive, though, $36? We need to get on with the lepton successor. I’ve tested yet another pre-made motor controller chip, and it was capable of driving my motor but could not change speeds properly.
I guess you could also put a ESP32 S3 in it if you were so inclined
I see @runger did a little follow up on Github too
Would anyone be interested in
“Adding a 22 ohm resistor between the transistor gate and the gate drivers”
I might be able to figure it out myself, but I’m still a noob to PCB stuff.
" Update Feb 23, 2024 - The EasyController 3.2 has been released, which has been more thoroughly tested than the 3.0. Further tutorial videos and build guides are coming!"
