DRV83053QPHPRQ1 using too low current
I’m trying to use 3PWM mode with the DRV83053QPHPRQ1, but whenever I use the example code, my power supply running at 12V, says the chip is only using 0.05A. Either none of the mosfets are turning on, or all the low side mosfets are conducting to ground. The BLDC motor I am using is the irotor 5010-360kv.
The code I used is here:
// BLDCDriver3PWM(pwmA, pwmB, pwmC, (en optional))
BLDCDriver3PWM driver = BLDCDriver3PWM(3, 10, 6, 4);
  driver.voltage_limit = 12;
  // driver init
  if (!driver.init()){
    return;
  // enable driver
  driver.enable();
  Serial.println("Driver ready!");
    // setting pwm
    // phase A: 3V
    // phase B: 6V
    // phase C: 5V
    driver.setPwm(3,6,5);
I’ve attached the schematic for my PCB here.
