Has anyone had any success setting up the current sense with the DRVs? I have some custom hardware based on the Odrive schematics and was working well with Odrive firmware. I now have SimpleFOC running on these ( runs better than Odrive firmware ) I have them running perfectly in voltage/velocity/angle modes and have now been trying to set up current control.
I’m using 0.0005-ohm shunt resistors and the default DVR gain settings which are 10. In the Odrive firmware, a gain value of 22 worked. I have tried 10,22,50 and so on with not much luck. I’m getting very unstable readings, the current readings will jump all over the place anywhere from -1 to 2 - 3 when the motor is actually drawing around 150ma. The Q, D reading were also all over the place around -1400 etc
The Shunt resistors are connected to the ground. I don’t know if this has anything to do with it ( I have tried inverting in software and not much change, still unstable ) Do the gain settings in the DRV need to be altered via SPI rather than in SimpleFOC.
I have been through the DRV datasheet to try and get the best understanding I can, but I’m a bit lost and don’t know what to try from here, here you can see the specific current sense stuff from the datasheet. Pages 9 and 16
The current sense code is far from ready in the main branch. Proper (low-side) current sense requires you to sample the ADC at a precise moment and it can prove to be challenging.
I’m working on a SAMD21-based solution, which you can find here, and I’ve just returned to it right now. @Antun_Skuric and @runger are not comfortable to pull in so much implementation-specific code (and I think they are right, yet I think what I’m trying to do expose some limitations with the current (pun!) implementation.
Right now I have an angle loop “working” (can’t seem to be able to tune that pid right, but at least it’s vivrating around setpoint and fight to get back when I force it out with my hand).
I’m completely tired of tuning my pid by hand so I’m looking at the theory behind all this, hoping to come out if a more automatic solution (i.e. moving towards replicating TI’s InstaSpin)
