Driving two-phase (bilpolar) steppers with three-phase (BLDC) driver - Hybrid stepper motor
Hi guys,
I’ve spent some time testing and extending the HybridStepperMotor code and I actually love it.
It’s so simple and it allows to control the stepper motor with BLDC drivers that are much easier to find, and have much higher torque capacity.
I’ve extended the code to allow for current sensing support and the true FOC control, and an initial support for current sense alignment with the driver. This one has been quickly tested, it seems to work in my case at least. It needs more testing to figure out all strange the edge cases, but its not critical.
I would love to have this code in the main library and I’ve made a PR that does the transfer:
Of course in order to be easy to use we need to do much more code examples and explaining but it does work and I am very happy with the results.
Great work guys!
Here is a video of a NEAM17 controlled with the SimpleFOCShield v3.1, in foc_current torque control mode. (setting 0.5A positive and negative current)
Question: Which BLDC phase do the two wires connect to? The example here shows them connected to phase B, but in the code here it sets Uc = center, and the theory page here looks like the two wires should be connected to the mid voltage. I’ve used HybridStepperMotor successfully before with the two wires connected to phase B, but maybe that was incorrect?
I ran across a problem in the current sense code documented here, where the Clarke transform is being applied to hybrid stepper currents when it shouldn’t, and I’d like to know for sure that my physical setup is correct for testing the fix.
